Now, isn't that a sight to warm the hear of any railcar fan! Lovely! Especially like the way you made the curved perspex corridor connection for the car in original livery (Pale Green upper cab front). With one of the double-enders evidently getting 'Enterprise' red over blue, the only major MPD livery not featured in that great line-up is 'eau de nil'.
Keep the pics coming, please!
As some light relief away from the MPD's I made a start on Glenderg's Weed Spraying Carriage Kit.
A straight forward build so far, just waiting on some parts and instructions to complete.
You'd want to have a word with the forklift driver in the PW depot. He's put the container on the wagon upside down!
He also has the roof of the weedspray coach on the wrong way round!
If only the Kit Manufacturer would send the instructions I would not have to guess on what way things should go!
My Spoil Wagon Kit arrived from Leslie this morning.
Could not resist unpacking it to see what the build entails.
At first glance there's little to it but then you notice all the fiddly bits and a book of instructions 6 pages long. They are the most comprehensive kit instructions I've ever seen and even tells you what paint to use and how to mix it. Well done to your Model Builder Leslie.
Sadly I've had to pack it away as I've to much to complete before starting yet another project so it goes to the back of the list (well maybe).
Hi Kieran
Thanks for displaying the goods for me - I didn't dare empty a pack to photograph it in case I'd never get it inside again.
You missed the transfers, which were a special commission (and had ANOTHER page of instructions!).
Good luck with the build - as you say, the original idea of having a very few parts went out of the window when the hopper part was redesigned and introduced another half dozen or so "fiddly bits"!
Still, it'll keep you out a mischief?
Leslie
To go along with my MPD sets I wanted to model a Buffet Car so I looked to Worsley Works who do brass sides of the NCC North Atlantic Express Diner which was later converted by the UTA to run with the MPD's.
I used Comet's underframe and roof. I got a lot of help from Colm Flannagan, 33lima and Dhu Varren on roof and interior detail and am grateful for their impute.
I spent a bit of time on the interior as the windows are large and the inside is quite visible.
I used PP Kirtley Green as recommended by Colm Flannigan as the nearest to the "UTA Green".
Nice work Kieran,the coach looks fantastic and the interior is important with those large windows.The spoil wagon kit looks good also,a few of them will be needed for my NIR era.Great to see the northern stuff getting good exposure on the site.
Nice job on the Diner the North Atlantic coaches are so distinctive, a set in LMS NCC Crimson Lake behind a matching Mogul or U2 4-4-0 would be an absolute stunner.
I like the idea of combining the Worsley Works sides with the Comet parts, hopefully the business will survive following the owner Geoff Brewins recent death
Sad news indeed, I was speaking to him briefly after he came out of hospital but he never indicated just how ill he was
Edited by Kirley
To run along with ballast wagons I made over a year ago I wanted a Ballast Plough Van to with them and when Weshty announced a brass kit of a Plough Van I had to have a go.
His Kit is similar to his Brake Vans but the tricky bit (for me anyway) was the forming and attaching of the plough.
Working on the MPD's has given me more confidence in soldering so that is the method I chose to build the kit.
As you can see I've still a bit to learn on soldering but the beauty is if you made a mistake you can unsolder and re solder again.
I'll need a strong contact adhesive to stick on the roof to ensure there are no gaps between it and the body. A bit of colour next and by then the decals should have arrived.
Great job Kieran, an area I want to get into.
Nelson, you can use superglue, but it goes brittle and if its dropped the joints will break as the brass will oxidise under the glue. Soldering is the way to go.
I got some kits from Leslie a while back and I finally got a window of time to have a go at them.
The wagon is in 3 main pieces, chassis, front and hopper which is fairly straight forward but there is 16 supports along with brake shoes, hand wheel, vacuum cylinder, chains and hand rails that prevents this been a quick build.
Time to paint, add the small extras plus decals before the models are finished.
