Mayner
Everything posted by Mayner
  1. Modelling Irish railways is either a matter of ignoring the gauge issue like many modellers in order to get something running, or deciding whether to run with an established scale and vary the gauge, or use an established gauge and vary the scale. Unless you are absolutely determined to scratchbuild everything including rolling your own rails and casting and machining wheels its probably easiest to stick with an established scale. Having a 45mm gauge garden railway and seeing Ian Ramseys U Tube videos 15mm scale Irish narrow gauge with some of John Amstrongs live steam Irish locos and stock would be tempting or even an 8.6mm scale B141 or C Class, but I would probably need to take out a second mortgage and what do I do with all my small scale stuff. While the OO/EM/S4 thing in the UK is complicated enough Large Scale American G Scale is a real can of worms with 3' gauge narrow gauge stock modelled in three different scales 1:20.5, 1:22.5 & 1:24 all running on 45mm Gauge 1 track, not helped with Aristo Craft doing a Henry Greenly and producing a large scale OO with American standard gauge models produced over size to "make them look more impressive" and other manufacturers following suit. Somewhere or other I have a presentable Schull & Skibereen Erin bought second hand from the UK modelled in plasticard on a Toymobile chassis, built like a battleship boiler fittings formed from bits of tube, bolts, washers etc John
  2. Very convincing I especially like the Simplex and the bus coach. I don't know about the present day even in the Mid 90s there was little in the way of Hi-Vis safety or work wear in Ireland, like most workers BNM staff (often farmers) wore their old clothes to work sometimes eve the old Sunday Suit. Depending the County the crew might break the monotony of the day with a kick about with a football or practice a ""puc fada" in hurling.
  3. I am not sure if any wagons fitted with the Morton handbrake in Ireland most of the unfitted wagons had a single brake shoe on each side operated by a long lever, a small number mainly CIE Pallet Vans, GNR Bagged Cement and Private Owner Tank wagons had independent either side brakes similar to the RCH type Most of the more modern fitted wagons had a parallel motion arrangement for transmitting the motion from the brake lever to the cross shaft similar to BR wagons of the same era.
  4. Rchie I am not sure whether your some Bluesky thinking is for producing some models for yourself or an attempt to undcut Dapol and corner the market Irish Wagon chassis kits. Whatever Popeye probably had the best answer make up a set of plasticard patterns and cast the chassis in resin http://irishrailwaymodeller.com/showthread.php/2508-Popeye-s-Workbench. RTV silicone is a lot better than maula should get 15-20 castings per mould, some wonderful solvent fumes and a lot of work cleaning up, but not as monotonus as cutting out 15-20 sets of parts from styrene. If you want the couplers to look the part why not try out a set of Smiths 3 link or Instanters wont drive you bugs coupling/uncoupling if you run fixed rakes.
  5. Richie. Quick maybe but nothing dirty about it. We seem to have been thinking on much the same lines. Originally started out as a chequer plate floor, stanchions and bit for upgrading a Prestwin, fold up chassis on the left added after taking a closer look. Whole thing fits together with slots and tabs. Not sure of the unit price yet but a skeletal would be cheaper as it uses less material. Rocking W Irons don't really work on a skeletal, there is enough potential interest for a sprung version from the S4 modellers in the UK.
  6. Riche Funnily enough inspired by Patrick's 27101 conversion I looked at a brass floor, buffer beams a brake gear to convert a Prestwin into a 20' flat, I came to much the same conclusion/confusion and the artwork for a brass 25436 flat is with the engravers. The aim was to produce a relatively straight forward kit designed to run on 21mm gauge, a chassis fabricated from brass is probably a better option for a flat as you haven't got the warping and shrinkage problems with casting in either whitemetal or resin. I drew this a few years ago but gave up as the 3D Printer & CAD packages don't want to talk to each other so I concentrate on etched brass and traditional pattern making. If you have mastered 3D solid modelling a 3D printed wax master for lost wax casting or a brass pattern may be a viable option for pattern making for whitemetal or resin casting, but you need to make allowance for shrinkage or expansion of the finished casting. The wax master would need cleaning up to remove ridges from the printing, which is really no different from machining and finishing a metal pattern
  7. My interest in Irish railways was pretty much ingrained in childhood experience, my grandfather on the mothers side was a driver on the Midland but had died before my time, in the 60s railway did not exactly have a positive image breakdowns and line closures, a sunday afternoon walk over pat of the Meath Line before it was lifted. Ours was very much a car family but got the occasional squint over the railway wall when we were driving somewhere, despite this I got interested in model trains, and persisted even if my parents hoped I would grow out of it The thin end of the wedge was when I persuaded my mother to buy a copy of Model Railway News in 66 or 67, there was no putting the genie back in the bottle. The first Irish Layout that really inspired me was Malahide and Dromin Junction it was on display in the Kilkenny Shop in Nassau Street, around the same time I started reading the works of Iain Rice I could not et anything to work but his writing as like a breath of fresh air Around the same time an article on Castle Rackrent appeared in the Modeller a minimum space WLWR broad gauge layout, which later morphed into something much bigger about 100'. I even got to see the original while living in Scotland. A couple of years ago I was surprised that 30 years later he layout is still going strong and regularly operated Time I stopped musing and did something to get something running I have a trio of Murphy Models B141s an AEC railcar set built from Worsley Works parts and a few kit built coaches, wagons and vans. Looking at steam the Lines North & West of Limerick were mainly worked by J15s with small 4-4-0s & MGWR locos appearing North of Limerick. I have a pair of J15s, a Midland Tank, some GNR locos plus some kits stashed away. All need some work control will probably stay analogue. Most of these kits were assembled 15-20 years ago the dilemma is whether to concentrate m energies on building new models to current best practice design or my existing loco stock.
  8. Although Abbeyfeale was a much smaller town than Newcastle or Listowel the station seems to have been reasonably important in terms of traffic serving as a railhead or a large area of North Kerry and West Limerick, at one time there were even plans for narrow gauge feeder lines to serve the town and villages south of the man line. During GSR days in addition to the three daily through passenger trains Abbeyfeale was the terminus off a daily passenger train from Limerick. The working was unusual by GSR standards worked by a tank loco and involving bunker first running as Abbeyfeale did not have a turntable. Abbeyfeale again acted as a terminus for a short while in the early 70s when regular operation over Barnagh ceased and the Limerick-Tralee goods trains were replaced by trice weekly trip workings from Limerick to Newcastle and Tralee to Abbeyfeale. Operation over Barnagh resumed and Abbeyfeale was served from Limerick for a short period following a bridge strike at the western end of the station. There is a photo of a supertrain livery B201 hauling one of these trains through Ballingarne in AJ O'Rourke's North Kerry book. Traffic to Abbeyfeale appears to have ceased with the ending of sundries traffic some time before official closure. The buildings and structures at both stations appear to be to a standard design for small stations on the North Kerry, including, Barnagh, Devon Road, Lixnaw and simply shouts out North Kerry. Abbeydorney originally had just a single siding the goods loop appears to have been added in GSWR days to break up the long section between Listowel and Tralee. Loads were restricted to 25 wagons between Tralee and Ardfert with heavier loads allowed westward to Tralee. A high beet loading bank appears to added in CIE days allowing beet to be tipped directly into wagons, Abbeydorney a loading ramp and possibly a mechanical shovel may have been have been used for loading beet from ground level bins. The ramp could only be used by one vehicle and was too steep for a truck or tractor and trailer. Signalling at Abbeydorney was interesting, while most of the shunting signals from the loop to the main line were probably the original with an upright revolving lamp housing, movements from the yard to the main line were controlled by a modern(ish) disc signal on a standard GSR/CIE galvanised steel post. from memory the disc was a disc rather than the square pattern often used by CIE. Next episode I will look at my most likely 4mm plan a simple U shaped design with two stations and an N gauge double decker walk around design to fit a similar space.
  9. Really impressive rake, I think the look far better reasonably clean than heavily weathered,
  10. The whole business of motivation is a very interesting thing, I think the majority of Irish based people who model the Irish scene for much the same reason as someone in the UK models the local scene because its familiar and achievable in OO with a mixture of rtr locos and stock, flexible track and points. Outside of Ireland the motivation is almost the reverse with a focus on the exotic aspects of Ireland's railways, much more kit and scratch building, a focus on fine scale wheel and track standards, the correct gauge, historic rather than contemporary and above all a focus on the unusual like the SLNCR and the narrow gauge.
  11. Just noticed Hibernia engraved? in the splasher marvellous stuff. Modelling the early railways may be becoming fashionable there was a recent thread in RM Web about the build of a OO gauge mode of a Liverpool and Manchester 0-4-0 with a motor in the tender with a carden shaft drive to the loco. Very smooth running but looked odd shunting BR steam era rolling stock.
  12. Looking at the cut stone work below the cabin it look like the GSR or CIE plonked one of its standard hipped roofed cabins on the base of an older box. I wonder how the signal man got the electric train staff for the Athlone Branch ain crews? A basket arrangement on a rope was for Navan Branch trains at Drogheda South cabin. Portarlington got very busy when main line train frequecies were increased and Galway & Westport services were diverted over the branch in the early 70s. The signal man would have needed an assistant to do the walking and climbing between the station and cabin, or possibly a subsidiary staff instrument in the station building to allow a staff to be remotely released while the signal man remained in the box. With greatly increased train frequencies and the Athlone Branch a main line the signal an would have been worn out waking up and down the stairs and crews no longer time for cup of tea and a natter between branch linearrivals and departures, In GSWR days Portarlington probably had East & West Cabins, the GSR& CIE re-signalled several of the larger stations like Athenry, Bray, Claremorris, Dun Laoire replacing a number of cabins with a large standard hipped roof box. I wonder are there any photos of the original?
  13. Happy St Patrick's Day. We had a 12 hour start on everyone bit bizzare sitting in a pub on a Monday morning with the other half having brunch, hardly anyone in the place, drinking Guinness & watching Ireland beat France. The downside was that Tuesday Morning came 12 hours earlier
  14. Inspirational stuff David although the larger scales are easier to work in, detailing takes 2-3 longer than 4mm because there is so much more that can be seen/modelled.
  15. I had fun and game trying to get an acceptable finish with the silver initially tried an automotive aerosol before trying a Tayiama flat silver enamel with much better results. Starting to look the part luggage van. SSM did a custom sheet of red numerals and letters for the silver vans. Flotilla of black & tan vans nearly ready for launch. Finishing these though a lot longer than expected mainly due to extremely humid conditions, in the evenings masking tape would not remain stuck to the model let alone paint . Decided on a SSM Inspection Car for a quick an simple project I could complete, also had a 35mm Blackbeetle out of a G Class. Swapped around the Lomac wheels for the 3' wheels supplied with the bogie. Could not resist the idea of a detailed interior with those deck chair seats, for a jaunt to size up the state of the track. Not sure if it was my Beetle the bogie was not symmetrical had to trim off a piece of the end of the gearbox at one end and cut off the pivot pin and raised boss in the centre. Its important to do a trial fit with the floor and power bogie to get the model to sit at the right height. As a late Christmas present I treated myself to a portable spray booth does a great job. To reduce paint build up inside the booth I line the base and sides with kraft paper,.
  16. The great Dunleer cigarette robbery. Dunleer was briefly re-opened to freight for a couple of hours in the 90s when a gang literally hjacked a 40' container of cigarettes off the afternoon Dundalk-North Wall Liner. Duneer station was a secluded spot, robbers used a mobile crane to do the lift empty container found a couple of days later. The Great Train Robbery video I interesting just before the BR corporate image era, the train appears to have been placed on the Aylesbury branch at Cheddington next station south for examination after the robbery hence weed grown trackwork
  17. Wow! Martello Towers and Hibernia 11/10 for originality!
  18. A brief look at the eastern end of the "main line" the busiest section of the North Kerry between Carey's Road and Ballingarne. Definitely worth including this section of the line possibly including both Patrickswell & Ballingarne in an American style possibly two level "walk around" style layout. The stations buildings on the original Limerick & Foynes line at Patrickswell, Adare and Askeaton are to a common attractive cut stone design, the track layouts very simple. Patrickswell and Adare closed to freight in 1974, the signal cabin closed in 83, Knock Pilgrimage and GAA specials continued to call into the late 1980s. A crippled CIE 20t brake and a GNR standard van with one end pulled out seems to have been permanent features until the siding was removed in the early 1980s. [ATTACH=CONFIG]12376[/ATTACH] Adare looking west. Patrickswell was the junction between the North Kerry and Croom Branch or more grandly named Cork-Limerick Direct Railwayt line from Charlesville originally a GSWR stalking horse to access Limerick the CLDR had running powers over the W&L to Carey' Road Junction where the GSWR had its own separate goods yard which handled freight traffic for Cork and Kerry, Guinnes, Grain & catte until the end of loose coupled freight. The station layout at Patrickswell was odd in that the Croom Branch and North Kerry were worked as two separate single lines through the station, no crossover was provided at the western end between the two lines, crossing two North Kerry or Croom Branch trains involved a shunt. The Croom branch lost its passenger service in the 1930, but the line remained an important freight link until Limerick Junction was re-modelled in 1967. The Croom Line had a nightly freight service to and from Cork, plus Castlemunget-Cork cement specials. Patrickswell closed The platform is a good example of Irish railway approach to regulation low and without ramps. A glimpse of Newcaste with the one time rather church like entrance to the station platform [attachment=:name] View along the platform from the stop block, difficult to guess what is original & what is re production. Terrance of houses on the right are on the site of the Goods shed and yard. North Kerry Yard was on the left hand side behind the station building. Next piece we will look at common features among larger North Kerry & Burma Road stations and a possible design for the layout.
  19. Personally I think using a Spud presumably to keep the cost down really lets down the model. The Spud is a nice bogie for running around at high speed, a Black Beetle particulary the 25:1 would have been a better option for a shunter.
  20. Mike Edge prepared the master for the DC Kits G Class, I am not sure if the Silver Fox G is basically a rtr version of the DC Kits loco. Going back to the B101s the engine room windows were clear I spent half an hour inside the engine room of 106 sheltering from a downpour during an IRRS visit to Inchacore Works The Birmingham Sulzers had spacious engine rooms there was room for about 10 people around the engine and generator.
  21. Well David got me thinking. Newcastle West another station with an unusual track layout, there are a number of photos in A J O'Rourke's book and the news section of the IRRS Journal from the early mid 70s I had a look around but did not take any photos before the track was lifted in the 1980s. Originally built as a simple terminus by the Rathkeale & Newcastle Junction Railway in the late 1860s, it became a junction when the Limerick & North Kerry opened its line to Tralee in 1880. The original station appears to have been a simple single platform branch terminus with a turntable and loco shed at the end of the running road and a single siding serving the good shed and loading bank. The single platform appears to have been extended and a second loop added for the opening of the Tralee line. This would have allowed two passenger or mixed trains to use the platform in a similar manner to Waterford. The diamond crossing arrangement across the down? running line to the goods yard was a fairly common W&L arrangement, Listowel had a similar crossover from the Up Main to the goods yard up to closure. [attachment=:name] The "North Kerry Yard" with a second platform road run round and turntable appear to have been added in the mid 1880s to allow longer trains to cross. The layout was later simplified with Up & Down main running along the platform and the diamond crossing and second loop removed, the down Home Signal from Limerick is now the down Home at Dromad on the C&L. Some re-signalling may have been carried out when the wooden signal cabin was replaced with a GSR/CIE hipped roofed block built cabin in the mid 50s. In CIE days the running line on the East side of the station appears to have been treated as the main line with the North Kerry Yard as a bay platform. The crossover near to the twin bridges at the Limerick & Tralee end of the station was laid out for reasonably high speed running, the crossover at the end of the platform much sharper. Passenger trains continued to run over Barnagh up to 73 with specials from Dublin & Limerick to the Listowel Races and Knock and seaside excursion trains. One special was made up to 14 coaches double headed by B141s with a relief loco sent to assist the run round at Abbeyfeale. The line had a brief resurgence in freight before closure Newcastle was the railhead for steel traffic for ESB in connection with transmission lines from Tarbert Power station. ESB leased the North Kerry Yard and both yards are chock full of open wagons in photos from that period. The final traffic appears to have been meat in containers from Rathkeale, cement and fertiliser to Newcastle. A couple of Back to Back fertiliser specials operated in the last few months, before closure. The last train delivered a H van of cement and returned with 55 empty wagons to Limerick. I haven't space for Newcastle but it would make an interesting major station on an American basement empire style layout with Abbeyfeale or Listowel or maybe both as secondary main line stations. Richard Chowan did much the same with his Castlerackrent, Moygraney and Western an O Scale WLWR broad gauge modular layout with models of several North Kerry & Burma Road stations.
  22. My Honda CRV is just about eligible to vote, 200k on the clock and still going strong.
  23. Might be worth listing the items on E-Bay or the RM Web classified, there still seems to be a lot of interest in old whitemetal kits in the UK. http://www.rmweb.co.uk/community/index.php?/topic/70333-what-have-you-done-with-your-keyser-kit/page-9 The steam tram, panniers and trams should be snapped up. Airfix body and Kemilway Chassis is probably for the Standard Class 4 2-6-0 may be more difficult to shift as Bachmann have released a nice rtr version of this loco.
  24. Funnily enough the group that built the Malahide & Dromin Junction layout in the late 60s whittled down oversized broom handles for their cement bubbles. Eamonn I like your drive for the inspection car, not sure if its still available Branchlines did very nice compact gearbox that would take the hassle out of meshing the gears and wear would be less critical on those un-brushed bearings. Setting up power pickups would be fairly difficult so a Blackbeetle may be the best solution
  25. Originally each province was more or less a law onto itself until the Colonial Government intervened in the 1870s, most of the early lines were in the South Island linking the local port with the hinterland. I think the first line was in Southland Standard Gauge weird Crampton locos and wooden rails. The Canterbury Provincial Government built North and South from Christchurch and built about 80 miles of 5'3" before the Provincial Goverments were abolished in the1870s. The track was re-gauged and locos and stock exported to South Australia. A couple of years ago I came across a siding laid in the old Canterbury Provincial Government double headed rail & chairs a p.w. mans equivalent of finding the lost arc The frugal Scottish settlers in Otago went for the new 3'6" gauge with Fairlie loco, one class were 0-6-4 back tanks complete with Inchacore style cab, bunker and outside framed trailing bogie.
