JasonB Posted September 12, 2016 Author Posted September 12, 2016 Lining has been added and some weathering done to finish it off 2 1 1
Glenderg Posted September 12, 2016 Posted September 12, 2016 Wow, that is a really impressive piece of work. The rust on the roof panels is sublime....hnnnng....
Dave Posted September 12, 2016 Posted September 12, 2016 Absolutely stunning I've been staring at those pics for the last 20 mins. The detail is fantastic.
craven1508 Posted September 13, 2016 Posted September 13, 2016 just the way we loved them!! filth and rusting away!! great job
JasonB Posted September 16, 2016 Author Posted September 16, 2016 Cheers lads thanks for the comments:tumbsup:
JasonB Posted November 26, 2016 Author Posted November 26, 2016 This has been gathering dust for a while so I thought it was about time I had a go at my SSM 42' bogie flat.Its just the one for now as this is more of a practice run for myself before going ahead and investing in some more.So far the underside spine and bracing have been added to the main frame and yesterday evening I made a start on the container locks which are tiny but well worth the work when finished. 1
JasonB Posted November 26, 2016 Author Posted November 26, 2016 Thanks for looking lads.I must admit Popeye it looked quite daunting when I opened it up first but once I got going it went together really easily.There's alot of cutting bending and filing but its well worth it when it starts taking shape.
JasonB Posted November 29, 2016 Author Posted November 29, 2016 The frame has now been completed and Ive given it a blast of primer.Its also had a good run and is working fine on curves and over points.Last job is to give it a couple of coats of red oxide and add the decals. 1
JasonB Posted December 5, 2016 Author Posted December 5, 2016 Other than a couple of small errors at the beginning which was down to me not bothering to read the instructions properly,its job done with some weathering to finish it off. 1 1
scahalane Posted December 5, 2016 Posted December 5, 2016 Very nice finish,love the rust on the containers.
Mayner Posted December 6, 2016 Posted December 6, 2016 I really like the weathering on the container really brings the model to life
popeye Posted December 6, 2016 Posted December 6, 2016 That's a great model build. Looks so real. What keeps the containers in place?
richrua Posted December 6, 2016 Posted December 6, 2016 Really great work. It is very realistic. How is the rust done?
JasonB Posted December 9, 2016 Author Posted December 9, 2016 Thanks for the comments guys very much appreciated.Popeye the 40ft sits nice and snug onto the flat and doesn't move at all which is great.The 20ft however is just sitting on it in the photo so once its on the move it will fall off.I do have a couple of ideas in mind how to sort it so it should be an easy fix.Rich the rust is made up from Humbrol weathering powders.I use a mix of Iron oxide Dark earth and Rust.I just brush it all over the area I'm working on and then gradually take it back off until I get the look I'm after.Once that's done just seal with matt varnish.
JasonB Posted January 5, 2017 Author Posted January 5, 2017 Here are some bagged cement wagons that I've started a little work on.I picked these up from Irish Freight Models to run with my 4 wheel curtain sides as I always liked the look of them mixed together in rakes when in service.
jhb171achill Posted January 5, 2017 Posted January 5, 2017 Little touches like this do big things to realism!
JasonB Posted January 7, 2017 Author Posted January 7, 2017 Little touches like this do big things to realism! Thank you Jhb.
JasonB Posted January 8, 2017 Author Posted January 8, 2017 One left to cut and as you can see I have taken off the bare minimum but I think it makes a big difference to the appearance of the wagon.I'm a lot happier with how it looks now sitting on the chassis. 1
popeye Posted January 8, 2017 Posted January 8, 2017 Why are they two different sizes? Are they two different makes? One has 6 ribs & the other has 7, so you could remove the bottom one.
JasonB Posted January 8, 2017 Author Posted January 8, 2017 Why are they two different sizes? Are they two different makes?One has 6 ribs & the other has 7, so you could remove the bottom one. That's what I have done Popeye.The one on the left hasn't been cut yet its the last one from 7. 1
DiveController Posted January 8, 2017 Posted January 8, 2017 (edited) When you look at photos of the prototype it seems that the doors covered and sat slightly outside the sole bars of the wagon dropping almost to the height of the brake lever when closed. The model seems to have been designed with the correct number of ribs but sits atop the solebar creating an awkward tall aspect to the model. Ideally the solebar would need to be reduced to allow the top to sit over it, which may not be possible. The profile of the wagon is very much improved. Nice modification:tumbsup: Glenderg posted some shots which demonstrate it fairly well http://irishrailwaymodeller.com/showthread.php/4286-MIR-Drop-Side-cement-Wagon?highlight=drop+side+cement Edited January 8, 2017 by DiveController
JasonB Posted January 8, 2017 Author Posted January 8, 2017 When you look at photos of the prototype it seems that the doors covered and sat slightly outside the sole bars of the wagon dropping almost to the height of the brake lever when closed. The model seems to have been designed with the correct number of ribs but sits atop the solebar creating an awkward tall aspect to the model. Ideally the solebar would need to be reduced to allow the top to sit over it, which may not be possible. The profile of the wagon is very much improved. Nice modification:tumbsup: Glenderg posted some shots which demonstrate it fairly well http://irishrailwaymodeller.com/showthread.php/4286-MIR-Drop-Side-cement-Wagon?highlight=drop+side+cement Cheers Dive.Exactly as you say,when I was comparing the model to photos of the prototype it just looked too tall to me.But it not only looked too tall it was when I had it alongside my curtain side cement wagons which was the reason behind cutting them down.Next job will be to put them back together and add a little weathering and they should look fine.
