Improving the looks for MM 141/181
I got 187 of Dave Bracken last Saturday. But one of my pet hates with the MM 141/181 is that when the coupler is fitted you have a big gaping hole on the front of the loco for the coupler to attach to the bogie. The other problem when double heading using the Kadee's some times the 2nd loco would cause the front one to derail on some points due to the bogies pushing together.
So I decided to try and over come these problems and improve the look of the loco by not having that big hole in the front. I have had great success with the MM201 using the same method I am going to show you.
First of all remove the bogie side frames from the loco. Then with a sharp scalpel cut away the existing coupling box
You then need to glue in the front cover panel. I used plastic weld to do this and I also ran a beed of superglue around the back of the panel as this panel is what will take all the weight of your train. I also filled in around the panel and sanded it down
Using a piece of Evergreen Box section I cut it to the exact length of my Kadee coupler. This will also be the same for the standard coupler that comes with the loco. The inside of the box section is 4mm x 2mm
Next I used my Kadee height gauge I marked where I wanted to locate my coupler box and then I drilled and cut out the hole for the new coupler box
Don't forget to glue in the coupler box securely as this needs to take a lot of pressure when removing and fitting the coupler
I then repainted the new front valance and fitted my coupler. The great thing about this system is that you can fit all the detailing hoses airlines etc to the front of you loco and your coupler still works. This is the first 141/181 I've done and I have ran 187 with every thing from MIR wagons to Cravens and I've had no problems at all
Here is 187 pulling a rake of MIR container wagons. If you want to see more pictures of her weathered up go to my work bench by clicking the link below
http://irishrailwaymodeller.com/showthread.php/37-Anthony-s-Workbench/page15
Edited by Anthony
Love the bridge guard rails too Anthony - did you just glue them in place?
Well spotted mate. I had them on other parts of the layout and Wrenn noticed last Saturday I hadn't fitted any over the bridge. Yes the are just glued in for now but I must get talking to the likes of Rich to see if he can come up with a more realistic solution instead of just glueing them onto the sleepers. Maybe if he reads this he could start a thread on the subject. Anyone any photos of the real thing.
I've read it alright, I am always looking you don't see me but I'm there. Anyway Anto the subject of guard rails is a minefield when it comes to how they are laid. On most examples of bullhead rail that you see on bridges or viaducts the guard rails are held in place by check chairs. Flat bottom rail guard rails like those on your bridge are another different story altogether and it varies from place to place as to how it is fixed.
The main objective of the guard rail is to limit the chances of a derailment and they are also installed in areas like railway stations where the platform has a long and continuous curve, an example being this pic of Waterford Plunkett. The inner and center lines are fitted with guard rails because of the gauge widening on the curve. The guard rail is held in place by check chairs in this instance.
I have only ever seen one example of flat bottom rail, guard rails before and they were held in place by a system of base plates, bolted to the sleeper, and bolts through the outer rail and the guard rail like in this pic of a check rail in a point at Waterford West.
Guard rails are often seen on the outside of the running rails but I never seen that system in Ireland. To be honest if you wanted to model the fixing of the guard rails Anto you would probably have to remove the track, drill the rails, make your own base plates and maybe use some styrene rod to represent the bolts, and some square styrene for the blocks between both rails. I think the fact that you bothered to install guard rails on your model at all deserves a =D as most people wouldn't think of doing it, so more kudos to you for doing it. By the way it looks great.
I will certainly do some more research and see if I can turn up anything else that might be of use.
Rich,
Sorry to change the subject away from guard rails, but I have a question for Anto, does the new coupler set up work okay on tighter radius curves?? thinking of doing a small shunting layout with 141s/181s and they look so much better with your mod I want to try it out.
Dave, were those pieces not geared towards easy railing of stock before a running session?
No idea Pat, just lying in the end of a box of stuff,
I dont imagine a curved piece of track aiding railing of stock, which would be easier to rail on a straight?
Anyway there they are..........
I would say they are rerailers.
Yeah it's easier to rail on the straight, but these may be supplied in sets that just contain a simple circle of track.
The tightest point I have is a peco medium. I fitted out a couple more 141's and using Kadee #17 I actually have the buffers working now and no problems. With some stock you might need a longer Kadee something like a #20 but to date I've no problems on my curves. The tightest curve I would have would be a 2nd radius
Nice conversion there. I've a couple of 141s to convert to get me going on the broad gauge before I start time travelling, so it'll be useful to me.
Tara Street has check rails. The rails themselves are square, slightly wider and than the head of the rail and as deep as they are high. They're held in fairly massive special chairs, which hold the rail and the check rail, and the chairs are held down with pandrol clips. Ciaran Cooney has some reasonable shots on Eiretrains. If I can get some close ups over the next few days, I'll post them here.
Alan
  • 2 years later...
The links to the photos in this thread are broken. Did anyone happen to download the photos from the thread as the original owner likely does not have them any more?
Thanks in advance if you have them
Edited by DiveController
I was actually thinking of doing the same recently but couldn't find the thread! Hopefully the OP or someone has the images somewhere!!
Anthony's super photos are still there on photobucket: http://s67.photobucket.com/user/anthon007/media/011-2_zps90518739.jpg.html?sort=3&o=828
Anthony's photos:
Edited by Noel
