Baby GMs move to Connolly.
Today is the day finally. The 3 RPSI baby GMs stored at Inchicore will move to Connolly within the hour. Locos 134,141 and 175 will be hauled by 071 in the retro livery due to head off a 10am. A photo stop is due at Drumcondra station just before 11am before the final short trip to Connolly shed.
Wish I could be there for it but stuck in work:((, if anyone can get any pics of the event that would be great.
EDIT
Just been informed that the transfer has been cancelled at the last minute due to "operational issues".
Edited by Railer
On Tuesday 19th July, IE 071 in its retrotrain CIE livery was used to haul the RPSI diesels B141, 175 and 134 from Inchicore to the RPSI Shed at Connolly.
Click the picture below to view all the images from the day.
Thank you. Great photos. Pity about the lack of maintenance on Connoly shed with weeds and shrubs growing from the roof that will ultimately damage the brickwork. Locos look great though. Are the three locos going to be stabled there permenantly?
And two from me taken of all four locos at Inchicore before departure this morning. [ATTACH]24641[/ATTACH]
Fab pic. It's interesting to see the evolution of the loco bodies side by side in historical order from 121 through 141 and 071. Each evolution the side aprons under the sidewalks got shallower and shallower.
Nope. Fixed. I may have done the RPSI some service in this regard.
Evening all,
As mentioned above, the RPSI moved their diesels from Inchicore to Connolly today in two moves. Click on the photos below to view them full size
Album link -
Quick question - why does 175 have that coupling on her?
Regards,
Kieran
I don't want to venture too far off topic, but am I getting the impression from the photos that Connolly Shed is no longer in use by Irish Rail, other than for re-fueling?
I don't want to venture too far off topic' date=' but am I getting the impression from the photos that Connolly Shed is no longer in use by Irish Rail, other than for re-fueling?[/quote']
It's now used by the RPSI.
Regards,
Kieran
It's probably an emergency coupler since she needed a tow at that end coupled to 141 and couldn't be turned. There's a standard one on the trailing end
Edited by DiveController
Not exactly right....when 175 was being used as the pilot loco around Inchicore before withdrawal the coupler was used to shunt Mk4 coaches,
It is seen here in the dropped position.
Whilst on the subject of the Inchicore pilot loco, which one is undertaking this task at present?
Stephen
An 071. Not sure which one (084 possibly, as I haven't seen a photo of it out recently and it still works)
Thanks Noel. Hadn't noticed it before
Thanks, Noel:tumbsup: Interesting fact
Hi Richie, would you like to elaborate? :)
E.g: have you modelled that building complete with weeds and shrubs growing on it and gutters blocked with weeds?
085 had a similar coupler fitted like 175 when it was confine to the works just before and a little after its overhaul. It also carried a DMU/EMU tow bar across it's buffer beam along the Mk4 autocoupler adaptor.
  • 5 weeks later...
134 was started today, I do love the hum of a baby gm
Aaah, yes! that's good to see and hear.
Does anyone know how much it costs to get a loco or coach back on the rails in preservation? Obviously 134 may be in better shape than say a steamer but just a ballpark figure?
Great to see,you just cant beat that GM sound:tumbsup:
+1
Brought me back to the early 60s on 121 hauled trains to Galway - sounds pure magic nostalgia
It really does depend on what you need to do, but for example a new set of batteries (always required!) can be easily €5000-6000 (a set of Deltic batteries costs £6000 in total).
Some restorations in the UK have cost upwards of £300,000. The only one I really know about is the Deltic Preservation Society's refurbishment of 55015 Tulyar, which has been a complete rebuild from frames up, with new sheeting and bogies. The air tank overhaul alone cost £3,474. Grease for the suspension, 100kg, was £480. A new set of bogies was an eye-watering £150,000!
£250k for the mechanical overhaul of a small narrow gauge tank locomotive, plus some new platework & new wheel centres http://www.whr.co.uk/appeals/russell-rebuild.
More machining and specialist work tends to be contracted out these days, volunteers are getting older and scarcer.
Thank you both. That's more than I thought it might be especially for a narrow gauge tank loco! I really have no idea how the preservation groups manage under those circumstances
