Decoder identification by Manufaturer ID + VER
Noel
Hi Folks
Could anybody please direct me to website which might allow me to identify decoders by their manufacturer ID "plus" their decoder version number. I know about the NMRA manufacturer list http://www.nmra.org/sites/default/files/appendix_a2c_s-9.2.2.pdf I can get both the ID and VER numbers using the programming track for locos that have unknown decoders.
But I cannot find any resource that maps decoder version numbers to specific decoder products.
I know basic Bachmann decoders (rebadged ESU lokpilot basic) are ID 151, but can't find which versions 088 or 089 map to 36-553 and 36-554 decoder products. Similarly the later Bachmann decoders (rebadged soundtrax) are ID 141, but not sure if version 081 is the 36-557 decoder. Likewise it would be nice to be able to identify Hornby decoder products.
Many thanks
Noel
Hi Folks
Many thanks
Noel
Noel, was it the CIA or the KGB you worked for in you Spare time. :ROFL:
Irishthump of this parish might be your man, Noel
Clever little chap for a drummer.......PIMP
Thanks...I think!
The trouble with this is that some manufacturers publish comprehensive lists of their version numbers and some don't. This link might help you:
http://jmri.sourceforge.net/xml/XSLT/pages/DecoderId.html
It's incomplete and some of the info may be out of date but it's a start.
While I have you there Thumper
I have some chips that came from locos that were chipped but the buyer wanted them DC
How do I find out what the previous address was to reprogramme them
I use a Power Cab Pro, it has aprogramme track.
Well I have one, I dont use it very often
:trains:
Well you can either put them into a loco and read back the address on the programming track or you can just reset them by writing 8 to CV 8 which will set them back to default which is address 3.
:trains:
You've got me there... I don't know the process for programming with the Powercab. That's the thing, it's different for every DCC system.
With the loco or decoder on the prog track
- press prog four times
- press enter
- press 1
- press enter
You should now see the set address.
Exactly as Stephen said. NCE steps below to view OR set short (1-127) or long loco address (128-9999).
Edited by Noel
Just wasted half an hour pressing buttons
Got all the info above but I still cannot get the loco to run on the old address or else programme a new one
Tried it on a couple of locos so I seem to have a problem, Heuston?
Has anyone actually found out the old address for a chip using this info?
Any chance there's a problem with the controller?
Hi Dave
When you press Prog/ESC button four times to select "Use Program Track" and then press 1 do you see a message like the pic below?
After a few seconds that message should change to something similar to this one but with a different number.
If the display did not change then there is a problem (i.e. no manufacturer ID is displayed)
  • Wiring to "programming/test track" from the NCE box
  • A fried decoder on the loco
  • A problem with your NCE controller - most unlikely if it can drive other locos
If the display did change to the second image, then press ENTER button twice and follow the sequence on the other post I made to read back what the decoder address is, or to change.
I ran a sound 141 on the main track and it worked fine
Going to drag them down to the MRSI this evening and see if there is anyone there that might know something about them
(Have to wake them up first)
We use Gaugemaster controllers so should be somewhat similar to the Power Cab
It's a much simpler process with the Gaugemaster controller but you need a programming track.
Noel
Got both of those readings
In your previous post, and thanks for the help by the way, I got the same reading at #5, decoder ver : 089
Going back up men, if I'm not back in 10 mins let the dogs loose....
OK that's positive. The test track is working, the decoder is responding and the NCE controller is working. Now just need get steps 6 through 9 working for you. As suggested the easiest is to reset the decoder on the programming/test track by writing 8 to CV8 which will give the decoder the default address of 3. Then test drive the loco by selecting address 3, and if that works then back to the programming track to give the decoder the address you would like it to have.
  • Addresses in the range 1-127 are short addresses and can be setup using steps 6+7
  • Addresses in the range 128-9999 are long addresses and can be setup using step 9 (and 10 not shown)
After you enter an address you are give the option of activating it by pressing 1. So if you press PROG/ESC after activating a short address then it is active, but if you continue on to step 9, enter a long address and then activate it by pressing 1, you have a long address (i.e. even though you already entered a short address in an earlier step, but it is ignored if you activate the long one).
As a former software designer I find all of the DCC systems have a rather awkward and jurassic user interface that is hardly friendly. The ECOS at least makes a decent stab at making all this guff a bit more user friendly, but jeapers we've been living in a smartphone era for 7 years now and the DCC manufacturers are still living in the MS-DOS era of the early 90s. Technology should be invisible and intuitive. Believe it or not NCE is supposed to be one of the less cumbersome old style system to configure. DCC needs a redesign and a new NMRA spec - it is jurassic. All of this stuff should be setup using smartphones and tablets instead of expensive dedicated and proprietary hardware.
Have to say the Gaugemaster Prodigy is dead simple, that's why I chose it in the first place. I had watched several videos showing how to programme with systems like the Powercab and Digitrax and it's seems needlessly complicated.
Hi Noel
You should get yourself a SPROG computer interface and do your chip programming on the computer, using the JMRI Decoderpro software. It's still a little DOS like with a Windows interface but closer to using smartphone tech.
It's very handy having all the options at a click of the mouse and not having to button walk through multi menu screens!
There are other tools in Decoderpro....
Eoin
Thanks Eoin I have JMRI. As you say its rather clunky but if you have to setup more than one or two decoder settings its easy to do compared with using the limited interface of a cab unit. It saves a lot of time setting up speed curves. The main reason I have JMRI is so I can use an old iPhone and iPad as zero cost wireless DCC cabs for walking around the layout (i.e. WiThrottle app). The app also allows clear labelling of function buttons which is great for sound equipped locos.
As to DCC systems, yes the MRC/Gaugemaster is a great system. I nearly went with it when switching to DCC last year but narrowly opted for the NCE because the cab ergonomically lended itself a little better to one handed use, and was a 5amp system. Being an IT bod I wasn't really concerned about the system programming interface, more of the ergonomics of driving trains once a system was setup. The NCE cabs lcd display gives good visual feedback of speed, functions in operation, direction, etc. I was drooling over ESU's fabulous Ecos 50200 system and its fabulous user interface, but didn't like the fixed games console size of the twin cab controller and the savage cost of their hand held cabs. NCE's basic cabs (e.g. cab04, cab05, etc) are truly hideous dating from late 1970s hobby electronics), but their power/pro 'dog bone' cabs like the MRC/Guagemaster appealed to me.
IMHO, the future of DCC controller interfaces is with wireless smartphone and tablet interfaces and all of the vendors need to up their game from their dated ergonomics. The technical side of DCC should be buried under plain english smart user interfaces, and words like CV, BEMF, long loco addresses, should be unknown and invisible to users. If you want to turn up the volume of a sound equipped loco there should be a volume knob or slider bar, not a CV to be set.
Edited by Noel
A basic list of DCC systems with very approximate street prices. Most of the European gear like Lenz, Roco, ESU and Zimo are usually better priced in Euro zone than from uk suppliers.
It looks like many manufacturers will end up with black box systems controlled from smartphone/tablets (or PC ughh). But IMHO the one thing missing from a touch screen interface is the tactile feel of a throttle control without having to look at the screen. Ideally one should be able to hold and operate a cab/phone single handed and without having to look at it for throttle control.
Ok we have drifted a bit of the original question, but it seems there is no comprehensive list of decoders that matches ID/VER numbers, only IDs. JMRI makes a stab at it but is hit and miss. For instance it cannot distinguish or identify a Bachmann 36-553 from a 36-554 decoder. Looks like decoder manuals is the only method of getting version numbers. Anyway its been an interesting thread. :)
Hi guys, I have been reading this over the past half hour ( cannot understand how I missed it ) & I'm totally gobsmacked at the knowledge of you guys regarding DCC, I'm saying right now I haven't a clue as to what cv's or all the other stuff you guys refer to on the tread, but no matter, the other thing I think I noticed was the no reference to the Hornby Select or Elite, anyone care to comment on these, thanks in advance
Answer this question...
