CIE Brakevan.
Here are a few pic's of a CIE Brakevan that i built. It's not the right length, it's a 10ft wheelbase and i believe it should be 12ft. But i had started
to build before i found out about the correct length. To late now.
Edited by popeye
Popeye, that is very very impressive. Is the vacuum pipe scratchbuilt? The lamp brackets...!? even custom J hangers wow.. the brake gear underneath and the weathering is suitably sublime. It doesn't even look too short in the photo. R.
Hello Popeye,
nevertheless a great vehicle you built despite the wheelbase. BTW: I think I would not have noticed it... . I like the modifications you made to the underframe with these round spring-pots and also the nicely done weathering. Could you perhaps say a word how you made the brake pipes? I need a set to complete my A Class wich alas comes from Silverfoxmodels without pipes. Great work, thanks for sharing!
Cheers,
Gerhard.
Hi Thanks for the comments. The brake pipe is just a bit of guitar string. I never did learn to play that thing. =))
Nice! I've even heard of someone using the filament of a light bulb to do the same thing. Not me, honest... :P
At school I had a classmate that played the guitar very well, today he's a professional at our musical hall. He always told us guitar players jokes like this one that I remember best: What's the difference between violin and piano? The piano will burn longer... :facepalm:
Thanks for the hint, I will have to look for a shop selling guitar strings.
I made up some brakepipes using 0.6mm wire with 0.15mm wire for the ribbing, prototypically correct but looks too fine for a model. Guitar wire definitely is the job. D light gauge?
Guest hidden-agenda
Great end result.
It took a few months to build on and off. The lookouts or duckets were taken from an old brakevan. Here is a pic of my Ploughvan
also too short & the duckets made from plasticard it's hard to get the shape just right. the lines on the glass were made by scrapping lines across with a pin & run a black marker over the glass then wet your finger & rub it off then some will stay in the lines
that you made.
Edited by popeye
Very, very nice, and being scratchbuilt, you probably love it more than you would any superdetailed Backky or Hornby equivalent!
You could probably tell a tale for every square centimeter or it.:eek:
Guest hidden-agenda
Nice job and like the windows.
The chassis that was used on both Parkside Dundas 10ft underframe kit PA16 £2.00 or 12 ft kit PA10 £2.00. They are cheap & you can modify as you like.
I changed the brakegear & made my own buffers to make it look more irish.
I'll second that. Fantastic.
  • 3 years later...
[ATTACH=CONFIG]6703[/ATTACH][ATTACH=CONFIG]6704[/ATTACH][ATTACH=CONFIG]6705[/ATTACH][ATTACH=CONFIG]6706[/ATTACH][ATTACH=CONFIG]6707[/ATTACH][ATTACH=CONFIG]6708[/ATTACH][ATTACH=CONFIG]6709[/ATTACH]
Only found this old post tonight as I was trawling old threads. An absolutely stunning example of scratch building using plastic card, detailing, and then finishing off with a precise painting and weathering finish. Sublime and inspiring as to what can be done.
Clickey for page 1
Superb job, absolutely brilliant.
Jobs like this show that a modeller on an extremely restricted budget can still follow this type of example and produce something totally convincing. Top class job.
Thanks. This was posted 4 years ago, Time flies.
Now that the ballast wagons are on their way i will need to build another ploughvan.
