Noel Posted September 29, 2015 Posted September 29, 2015 Great progress. This really going to look the part. Quote
The Derry Road Posted September 29, 2015 Posted September 29, 2015 Lovely piece of work and so neatly put together, very well done. TDR Quote
Kirley Posted September 29, 2015 Posted September 29, 2015 Great steady progress with the benefit of working on an actual location - can't be beaten. Quote
Junctionmad Posted September 30, 2015 Posted September 30, 2015 How come you decided to omit the small goods yards sidings in greystones ? , they were there well into the diesel era ? Dave Quote
BosKonay Posted September 30, 2015 Posted September 30, 2015 That bridge is a lovely thing - how was it constructed? Quote
murrayec Posted September 30, 2015 Posted September 30, 2015 How come you decided to omit the small goods yards sidings in greystones ? , they were there well into the diesel era ? Dave Hi Dave Firstly closetmodeller's intended running is for the main lines through Greystones Station handling four trains to a time table- Timber Train, Commuter, Other Passenger, and the DART. Secondly closetmodeller desired a layout in liner fashion, for main line work, and not to take over his office room. Therefore the boards are 400mm deep and the sidings had to go otherwise the layout would be to cluttered. The outside siding still exists at Greystones and would have been nice to incorporate, but due to the depth of the baseboard it was omitted, as the station building is more important and we wanted to incorporate some of Main Street of Greystones Town in the layout. Eoin Quote
murrayec Posted September 30, 2015 Posted September 30, 2015 That bridge is a lovely thing - how was it constructed? Hi BosKonay The bridge is cut from insulation foam with the hot-wire cutter and then cut strips of foam are stuck on to create the walls and footpath. A paper template is cut from the CAD drawing to use as a guide for cutting- refer to Tips n Tricks section for home made hot-wire cutter... Eventually the bridges will be covered in printed stone work..... Eoin Quote
murrayec Posted October 3, 2015 Posted October 3, 2015 Hi BK Just thinking- you may be referring to the footbridge and lifts in one of the earlier photos- this can also been seen in the Tips n Tricks;- http://irishrailwaymodeller.com/showthread.php/4586-Hot-Wire-Foam-Cutting-By-murrayec?p=72001&viewfull=1#post72001 I'll have a few shots of it shortly as the stairs handrails are now etched and is currently in the paint shop.... Eoin Quote
driver301 Posted October 5, 2015 Posted October 5, 2015 Brilliant Work. Progressing nicely. Looking forward to more updates. Quote
murrayec Posted October 12, 2015 Posted October 12, 2015 Hi All Here are two shots of items for the layout hot off the work bench.... Handrails for the pedestrian bridge steps are now complete and all is ready to install on the layout This is the gate into the field to access the beach, it's from an SSM etch with foam-cut stone pier posts- old style, not many about any more! Eoin Quote
closetmodeller Posted October 12, 2015 Author Posted October 12, 2015 Hi All Here are two shots of items for the layout hot off the work bench.... Handrails for the pedestrian bridge steps are now complete and all is ready to install on the layout [ATTACH=CONFIG]20306[/ATTACH] This is the gate into the field to access the beach, it's from an SSM etch with foam-cut stone pier posts- old style, not many about any more! [ATTACH=CONFIG]20308[/ATTACH] Eoin Eoin, A first class job. Thanks Quote
Kirley Posted October 12, 2015 Posted October 12, 2015 Great work, the footbridge looks very intricate and the pillars set off Weshty's gates perfectly. Quote
The Derry Road Posted October 13, 2015 Posted October 13, 2015 Great piece of modelling, precision in detail, well done, TDR Quote
BosKonay Posted October 13, 2015 Posted October 13, 2015 Your skills with foam are beyond comprehension Eoin! Those gate posts are the real think, miniaturized surely?! Quote
murrayec Posted October 14, 2015 Posted October 14, 2015 Hi Thanks all for comments Yes BosKonay, foam is the business, such an easy, light & economical material to play around with. Allied with computer drawings to print out accurate templates on mass almost anything is possible Though Woodies don't do the pink stuff any more.... Eoin Quote
burnthebox Posted October 14, 2015 Posted October 14, 2015 Mega piece of modelling, that footbridge is the business, well done lads, Quote
closetmodeller Posted October 16, 2015 Author Posted October 16, 2015 (edited) The newly etched gate installed [temporarily] on the path and crossing to the beach. The footbridge has yet to be installed in its permanent position. Edited October 16, 2015 by closetmodeller Quote
Weshty Posted October 16, 2015 Posted October 16, 2015 Those pillars look really well, nicely weathered and a suitably "stoney" surface, shows off the gate no end. Quote
closetmodeller Posted October 23, 2015 Author Posted October 23, 2015 A selection of files showing further work on the model, this time mainly of the "timber yard" where the surface has been raised to track height, using card inlays. As usual the Master did the work. Two layers of card were used which will now be painted as appropriate to resemble a tarmac area. General view of yard and station in background Cutting out the infills The master at work Relaxing The first layer infill is tested for fit The seashore, with stones marking the tide line Second layer fitted, with B-T Models forklift trucks. This will now be painted to resemble tarmac. Quote
closetmodeller Posted October 31, 2015 Author Posted October 31, 2015 (edited) New pedestrian overbridge for station. Detail of Lift shaft. Edited October 31, 2015 by closetmodeller Quote
dave182 Posted October 31, 2015 Posted October 31, 2015 I love the detail there! Stairs and bridge kit or hand made?! The quality of modelling on this forum continues to amaze me, this is yet another layout on my watch list! Quote
The Derry Road Posted October 31, 2015 Posted October 31, 2015 very nice detail and well constructed model. I admire your eye for detail and your patience. TDR Quote
murrayec Posted October 31, 2015 Posted October 31, 2015 Stairs and bridge kit or hand made?! Hi dave182 It's hand made- foam, styrene, cardboard & etched brass, and a lot of work! Here is a sketch of the landscaping idea we have for the layout, the sketch is not to scale but this kind of thing allows one to calculate numbers and type, we reckon this is the minimum! interesting to see how that pans out;- Eoin Quote
Mike 84C Posted October 31, 2015 Posted October 31, 2015 Well done guys the detail is brilliant. For me the tide line on the beach makes the scene. Thanks for sharing. Quote
closetmodeller Posted November 6, 2015 Author Posted November 6, 2015 (edited) Greystones gets busy. A view of the layout from the "North" Edited November 6, 2015 by closetmodeller Quote
closetmodeller Posted November 6, 2015 Author Posted November 6, 2015 (edited) Greystones gets busy. The latest acquisition 2708 [ATTACH=CONFIG]20664[/ATTACH] Edited November 6, 2015 by closetmodeller Quote
Noel Posted November 6, 2015 Posted November 6, 2015 Nice work. You are really capturing the atmosphere of Greystones so well. Love the way you have done the beech. Quote
Dave Posted November 6, 2015 Posted November 6, 2015 It's really taking shape now, looking forward to seeing it finished. Quote
BosKonay Posted November 6, 2015 Posted November 6, 2015 Getting better by the post! When a layout starts 'feeling' like a prototype photo you know you are nailing it! Quote
closetmodeller Posted November 14, 2015 Author Posted November 14, 2015 (edited) The Master says that I should include some descriptive text. What follows is an imagined instruction to the Station Master at Greystones on the operation of the station. My interest arises because, uniquely, Greystones is the only electric service on a single track, where Greystones Station functions both as a passing loop on the line to Wexford and as the terminus of the Dart Commuter service. In effect the need to receive and dispatch Dart trains at relatively short intervals, while accommodating the other traffic through the station is what interests me. Because there is no passing loop between Greystones and Bray, all schedules are determined by the time a train takes to clear this single section. The same applies on the "Down" trains from Greystones, but here the scheduling is much easier, due to the low frequency of the services. Some remarks about the layout The narrowness of the baseboard and my desire to have a curved track through Greystones, meant that it would not be possible to accommodate the small yard in its prototype location between the Down platform wall and the sea. Similarly, the Dart storage siding points were a problem. I therefore decided to relocate the small yard off the Down line south of the station and to incorporate the Dart storage siding in the Down fiddle yard. An Up fiddle yard beyond the bridge at the north end of the station represents the line to Bray. I have assumed that the bridge over the Barrow remains in use for the timber service. Greystones Station Operations THE DART The Dart electric service takes general priority. UP Dart trains must be despatched exactly on time. DOWN Dart trains will normally arrive at the UP platform. COMMUTER SERVICE UP trains will depart from UP platform. DOWN trains will arrive at DOWN platform. Note: DART Down trains will arrive at DOWN platform only when it is necessary to leave the UP platform clear for UP Commuter trains. Once these are cleared, the DOWN Dart must be moved to the UP platform, ready for UP departure. ROSSLARE SERVICE This train will not normally stop at the station. Passengers should not be admitted to the train should it stop, as this traffic is adequately catered for by the Dart and Commuter Services. Stops shown in the Working Timetable are for traffic purposes only. TIMBER FREIGHT SERVICES The imagined timber service to Belview Port requires the use of Greystones as a passing loop to relocate the locomotive to the head of the train. UP Timber trains will us the main line, including the DOWN line, to shunt these trains into the timber yard. Given the short length of the sidings in the Yard, all timber trains must be divided in the yard. The locomotive will remain in the yard, ready to haul the DOWN train. DOWN Timber trains, when marshaled, will be pulled to the UP line at Greystones Station. The locomotive will then uncouple, using the DOWN line to loop around the wagons, attach to them and then lead the DOWN train to Belview. OTHER FREIGHT SERVICES Company remains anxious to develop its freight services, especially through Roslare. With this objective in mind, occasional Special liner services may be run through Greystones Station, where possible at off-peak hours. These will be advised in the Working Timetable. ENGINEERING & WORKS SERVICES Pertrains, i.e. Sandite, Engineering and Works trains are run as required. These will be advised in the Working Timetable. Steam and other Passenger Specials These require special timetabling, which is negotiated with the train operators. In the case of steam locos, it is desirable that provision be made to obtain additional water for the engine, should this become necessary. This is the responsibility of the operator. Attached at some photos of some new senics. I particularly like the little shed, with bicycle and oil barrels. These are typical of the Master's creative abilities. The tide came in! The worker's bicycle leaning against hut in timber yard. Passenger lift shafts with over-bridge, at high tide The spur to the Timber Yard, with main line to right. [The yard awaits a concrete surfaced). Edited November 14, 2015 by closetmodeller Quote
richrua Posted November 15, 2015 Posted November 15, 2015 i am enjoying this one. I think it shows that patience and simplicity ( i mean that in the best way _ as in non-cluttered) really are an art form in model railways. enjoying watching the scene develop. Quote
closetmodeller Posted November 22, 2015 Author Posted November 22, 2015 The major project this week was to paint the timber yard a concrete finish and to try some planting. We have a fully worked out scheme for trees and bushes to be implemented. At the moment I just wanted to judge the effect of trees. B141 heading up the ramp to the "Timber Yard". Commuter DMU heading Down from Greystones towards Wicklow 2700 Class passing under bridge by some trees. Quote
