enniscorthymans workbench
Interested to see how you do the Sound and lights Eamonn, that Inspection car looks fiddly work but it should be nice when you get it painted up.
I am taking the lazy way out as regards using the chassis
Off a39.I was going to do a brand new SF body in IR livery
but had 001s body which all that needs is a detail kit.
Although I love a39,she is a bit out of place in the black
livery with other locos,and I thought the sound chipped
001 would be nice.I will get a deltic chassis for her at a
Later stage.The inspection car is slow work-but only a
bit tricky trying the get roof to fit right.
Eamonn, can i offer my 2 cents worth on this beauty - cut off the horn and get a pair like on the baby Gm's! makes the world of difference to what will i know be a great job. seamus
My workbench seems to give me more and more work,however
a mate who is handy with wood,turned out these cement bubble
tanks and I am going to try a build with parts from a prestwin chassis.
The inspection car is still going slow,however I am thinking
about trying this motor on the chassis.Not sure if this will work
but will come back to it later.
What is the weight like Eamonn, you won't need to ballast the wagons anyway. An innovative idea!
The weight seems to be fine Kieran,from what I can see no
need for extra ballast.I have one MIR bubble so I want to see
how close I can build it to the original.
Lovely hurling there Eamonn, the bubbles look like they'll be spot on and your making a great fist of the inspection car, and very clever transmission system too!
Thanks Tommy.I am trying to use up bits that I have,but the motor
might not work and I might have to revert back to 35mm black beetle.
The plan is to use a TCS T1 decoder in the main body and I have a few
LEDs that will fit nicely into the headlight holes.
Easy to do one, hard to turn them all the same and look consistent... well done to your mate. Nice bit of wood turning.
Would love to have a crack at doing Cement bubbles someday. All the components are readily available i.e.: Westy's detail kits, Railtech and Westy's transfers, Dapol prestwin for the Chassis. All that's missing is a Bubble! Nice way around that problem. :cool:
Funnily enough the group that built the Malahide & Dromin Junction layout in the late 60s whittled down oversized broom handles for their cement bubbles.
Eamonn I like your drive for the inspection car, not sure if its still available Branchlines did very nice compact gearbox that would take the hassle out of meshing the gears and wear would be less critical on those un-brushed bearings. Setting up power pickups would be fairly difficult so a Blackbeetle may be the best solution
Thanks John,I think I may take your advice and go for
black beetle 35mm unit.I did order one from a UK supplier
around Christmass but had a strange experience in that the
supplier would not send out my order despite some e mails.
I ended up having to cancel my order for the BB.
Do branch lines do Black beetle units?.
I finally got around to switching the chassis on A39 to IR 001.
I used some of the SSM detail kit such as roof grill and lamp
irons,CAWs protection thing on the front,wipers and headlight
detail.I also switched over the wiring for the headlights from
A39 so she has directional lighting as well as the sound chip.
I am delighted with 001 and she slots in for far more work
with the stock I have.I have a few photos here and a video
of her on the layout.The layout is in a bit of a state as a lot
of work will be done on that when the weather heats up a bit.
I'm loving that last photo with the A Class coming out of the tunnel. Loads to see, and I like the way you have the fencing butting right up against the level crossing. As well as the rural backdrop, sweet.
