enniscorthymans workbench
Lovely lovely work there, particularly the track weathering. Bang on!! 2nd photo is pure class. Very nicely composed scene.
Thanks Des, as you can see some of the roof
painting and weathering needs to be touched up.
She's a lovly little model to build.
Nearly finished my second ballast plough van.I had to sort the roof antenna on the first van as I made a bags of it first time around.As can be seen the roof has not been glued on the second van yet as I need to get proper glue that won't cause any clouding from super glue like what happened on the first van.Still a bit of touching up and weathering
to do.
Very nice! Have one of these to build myself, itching to start it seeing yours. Just started on the ballast wagons. Slow going!
Cheers Jim bo, would love to see photos
of your build.Building these kits at your own
pace is the main thing.
Next for me is plough van which in the process of the roof finally getting a bit of
Glue.I have 3 tankers to finish off as well.
The 121 has annoyed me for ages as the
Painting needs to be touched up along with sorting some sort of chassis.I have a class 20 chassis that could come into use, any ideas for it for a 121 or C class?.
  • 4 weeks later...
A bit of video showing the first run of the SSM ballast plough
vans.The track and layout need a good clean.085 has the
realdrive Mr sound guy on board.I will post up another video
when I get a chance to clean layout.
Nice video and good job with the ballast plough vans Where did you get the ballast wagons from??
Thanks for comments lads.
The ballast wagon body's are 3d
printed from shapeways and are
mounted on dapol prestwin chassis.
I used break pipes and brass hand wheels
from dart castings.SSM provide the decals.
Very interesting. I must try a metal kit but a little cautious and I keep getting distracted by other things. Are all the American locos for donors ? I often wonder why the ho american locos are quite cheap compared with oo gauge European stuff.
The Switcher body's were to be dumped by a friend
who used the chassis for 121s, so I rescued them as
they are beauty's. I don't know what to do with them.
The switchers came from a on line shop in USA and
are not cheap either.
Is the SD7 (Southern one) a Proto 2000 body? Might be interested if it is.
I am not sure Fran, I thought it was a Blue line
sd9 but you are welcome to it for free along with
the other switcher body's if they are of any use.
I have another sd body as well that can go.Both
could be missing some bits.The chassis was to
be used for a MIR 071.
Cheers Eamon, will take the SD bodies off you if that's okay? Will send you a PM.
