IRM Is Sucking Diesel As Fuel Oil Tank Wagon Announced
Irish outline announcements have been coming thick and fast in recent months, and instead of slowing the pace down, we've decided to add another one to the pile with our latest all-new wagon announcement; the CIE fuel oil tanker on the Bulleid triangulated chassis.
Prototype History
CIE_333A_Kilkenny_29_Sept_1968__TomWall-
With Corás Iompair Éireann (CIÉ) rolling out a series of freight stock throughout the 1950s-1960s based on a standardised triangulated underframe developed by its then-Chief Mechanical Engineer, Oliver Bulleid, attention turned to transportation requirements for the company’s own diesel fuel oil supplies.
Tank_2.jpg?v=1710948552
A total of 21 tank wagons were constructed at Inchicore during 1956 to augment and replace older types then in use. These tankers, with an 11-ton capacity, were a common sight throughout the network, conveying diesel from the importation point at Dublin Port to locomotive depots of all sizes, as well as occupying sidings at stations to supply CIE’s fleet of road vehicles in those localities. The wagons were frequently transported to and from these locations within mixed goods trains of the time.
CIE_23891_Sligo_Quay_18_March_1974__TomW
These tank wagons provided the backbone for this traffic across three decades, but the move to continuously-braked goods trains and the associated improvement they offered to the safe handling of flammable liquids resulted in them being displaced by vacuum-braked tankers towards the end of the 1970s. It was not quite the end of their story, however, with the tank bodies and main underframe sections going on to find further use installed upon newer vacuum-braked wagons to convey water as part of the CIÉ/Irish Rail weedspray train, remaining in use until the early 2020s.
The Model
CIE_Bulleid_Tank_web_Images_square_v1.jp
Tooled as part of our Bulleid triangulated underframe project, our CIE fuel oil tanker wagon is the third model of our latest wagon series and an essential part of both mixed goods trains of the 50s, 60s and 70s. Perfect for both mixed goods trains, fuel transfer trains and also any Irish locomotive depot or CIE bus or road haulage depot sidings, our high quality tooling features a wealth of etched metal and high quality injection moulded plastic construction.
Tank_1.jpg?v=1710950463
Easily convertible into 21mm gauge and complete with separate brake gear, intricate fuel filler cap detail, brass bearing cups for excellent running capabilities and sprung buffers, these wagons will be some of our most detailed wagons to date.
Priced at €89.95 for a single triple pack, production delivery is slated for Q3 of 2024 with decorated samples due in the coming months. Production quantities will be limited, so make sure you get your pre-order in soon to avoid disappointment.
Pre-order via the link below.
Pre-Order Your CIE Fuel Oil Triple Pack By Clicking Here!
View the full article
  • Like 14
  • WOW! 2
Amazing! I've just finished up plans for a fuel area for my layout yesterday evening. Great stuff lads!
On a side note, is there only going to be one pack of running numbers? Thought you might do the usual 2-3 packs of different liveries (Wallet might not complain though)
  • Funny 1
Sucking Hell, this will loosely-brake the bank, I'm oilready in the red!
EDIT:
How does one pre-order?
Clicking the green doesn't do anything, and there's no black button as with previous pre-orders:
Edited by DJ Dangerous
Need To Buy Now!
  • Funny 3
  • Angry 1
1 minute ago, meathdane said:
Don't start with these pun based shenanigans again!
Just say Tanks and move along
Don't be so rigid bodied, no need to put a filler cap on the puns just yet.
That was a greasy one, sorry. Also woefully Esso-teric.
  • Funny 6
This isn't fair, you're much better at puns than me, I'm starting to feel a bit Bulleid. I'm only gonna be a Shell of my former self after this
  • Funny 4
EDIT:
`Seems ok?
Yeah, kind of surprised at just the one pack being offered - would like to have seen a version suitable for the late 90s - early 2000s, such as the three that hung around Limerick depot or the ones at Connolly
It sounds like that would require a newly tooled chassis:
I'm sure we'll see them eventually.
The IRM modular approach reaping the benefits, take tank barrels from weed spray set and stick them on the Bulleid chassis for a whole new model!
There is some lovely footage of an E shunting these on Horgans quay in cork that was shown in an IRRS slideshow a few years back
  • Agree 2
Quick Question
I expect these are Engineering Samples with a lot of detail to be included just yet?  so just wondering before the final cut is made will the 'plate' in between the support cradle be to the top of the supports where the red line is and the supports slimmed down?
The Leaf springs seem a bit Curvy too? Not compressed so load inside?
Also the ladder seem to be over the that support plate when in the real examples they are to the left of it?  or are there subtle differences between some wagons?
All me books are packed away at the minute so just going by the photos you supplied.image.thumb.png.ce33260d55a44b4fc9e5e2efe5314311.png
image.png.3123d089d2bd8608c6c05304a0448af3.pngimage.png.5c2e644379d882276c4d949b9d20c758.pngimage.png.485f0dedfc118a4727546e556ea8a9c4.png
Edited by Georgeconna
  • Informative 3
EDIT:
Having the same issue as DJ when I try to pre-order. No pre-order black button!
Just keep refreshing the page. It will load eventually. It's like a plug-in or pop-up or one of those widget things, appears after the other ones like the chat and rewards have loaded.
53 minutes ago, Georgeconna said:
Quick Question
Hi George,
You bring up some good points and have identified some of the areas that will be improved on the finished production models. These will be corrected on the finished models.
Cheers!
Fran
tried that DJ still no joy
Great addition to the range. Surprised to read there were only 21 of these, as there always seems to be one or two lurking around somewhere in the background of any photo of practically any large engine shed or goods yard in the 60s or 70s. I'll be ordering a set for sure.
Would these be different to the ones on the siding at Limerick station? The support plate between the tank and body looked different.
Great looking model guys.
21 is a great number for IRM: 6 more triple pack re-runs down the line to look forward too 🙂
  • Funny 4
That'll teach me for rushing to type a post when thinking through the fog of work
  • Funny 1
2 hours ago, BosKonay said:
make sure your browser is not blocking cookies?
works when I use Edge but not Firefox which is my normal browser which worked fine until now
