murrayec's Projects
Refer to Volume 1 at; http://irishrailwaymodeller.com/showthread.php/2346-murrayec-s-Projects?p=34623&viewfull=1#post34623
Hi All
I have been developing up a baseboard layout drawing for the Seapoint Martello Tower, its not yet complete but I thought I would share some images on the layout because its based on the 'Modular Baseboard System' see thread; http://irishrailwaymodeller.com/showthread.php/2465-Modular-OO-Layouts?p=37052&viewfull=1#post37052
The layout runs across three 1200x600mm boards, two transition, and one feature boards, though the transitions have some of the feature on them. The two main line tracks move to the back of the feature board to allow for Seapoint features and the tower to fit, incorporating 4th radius curves to do this. This design complies with the Modular System.
As you can see I have a lot to sort out, this is why I prepared these renderings from the drawing- sometimes its easier to see things in a mass model than line drawings. (no, heirflick that's not a religious dancer) The Tower stands to high but I don't have enough space to get the ramp over the Ordinance Bridge longer to lower the tower. I may look at lowering the embankment and bridge- though the bridge is set up for catenary! Another idea is to have a front extension to the board to give a bit more space but dont really want to do this, I'd rather stay within the 600mm module.
As I have said before, this is a truncated Seapoint layout but I think there will be no doubt as to the scene location.....
murrayec
Very nice 3d graphics there murrayec. Really helps visualise the finished idea. What software did you use for it? It'll be a very unique setting, your DART model will look right at home :D
Tom
Thanks Tom
Its done in Autocad, just solids extruded from the drawing with autocad colours. Autocad has a basic rendering facility, its not to complex if you don't get into mapping materials, playing with lights and cameras. 3D Studio Max is the one for that...
I cant wait to start cutting foam and get the boards set up...
murrayec
  • 1 month later...
Refer to Volume 1 at;- http://irishrailwaymodeller.com/showthread.php/2346-murrayec-s-Projects?p=47583&viewfull=1#post47583
Hi All
Here are a few shots of the bell-cranks, drive rods, cross-heads, and cross-head drive rods, - etched in .5mm brass, just out of the acid bath. It took me a few goes to get it right, its a fine balance of the right coating of photo resist, the correct UV exposure, and a strong mix of acid! Some detail has been lost on the drive rod ends but these parts are good enough to work with assembling the test model, I'll make adjustments to the print tooling and acid mix next time around.
The parts were etched from both sides so that the main drive rods and bell-cranks have a bit of 3D, the drive rods are of two components which will be sweat soldered together to give thickness. Also etching from both sides reduces the edge cusp- the parts stay close to size, so less edge cleaning up with a file. The magic etching formula was used in the print tooling for parts over size and all holes are etched under size.
Next on the list is the bell-crank main bearing housing, when that's complete the drive and crank system can be erected, the motor installed and a test run of the system!!
murrayec
You Sir, are a lunatic.
It'll be the effects of the exposure to all the acid.... PIMP
It been great to watch the evolution in this thread. Can there be anywhere further to go?
Hi Guys
Thanks for the great comments
Hey Broithe, here is something further- does this count?;-
A friend makes these beauties and I assist with hole drilling, decals, ideas and holding! The Cigar Box Guitar's he makes are deadly, they look great and sound the part. The fuzz box is his own design and he calls it 'Atom Fuzz'. Check out 'Helium Dog' on facebook if you want to see more.
murrayec
Hi
I have been asked by a member to show how sweat soldering is done, I will post a few photos and explanation when I'm doing the Hibernia drive rods. But in the mean time here is a link to an over-view to soldering which may help, it includes a bit on how to sweat solder;-
murrayec
Edited by murrayec
Broken Link Fixed
  • 5 months later...
Refer to Volume 1 at; http://irishrailwaymodeller.com/show...ll=1#post34623
Refer to Volume 2 at; http://irishrailwaymodeller.com/showthread.php/2346-murrayec-s-Projects?p=49204&viewfull=1#post49204
Hi
Eventually, tonight, I got to stick on the hardware & tackle on the cannon! This should have happened last week for the MRSI show but just could not find time to do it.
The cannon is turned from a piece of aluminium rod with a brass cross-piviot-bar set through below the centre line of the barrel. Brass straps are pinned over the pivot bars on each side and into the gun carriage to hold the cannon in place and allow it to pivot. The blocks are made from lolly-pop stick, with brass strap stuck on and a hole drilled through for the ropes, and black paint for the pulley edge!. The blocks are a tad to big- so maybe I'll have another go at them in the future.
The 'racer' as the tracks are called is painted styrene card, this area needs a bit of fettling as I had not allowed for the card thickness and the gun is a bit high. There are 4 little brass wheels in brass inverted stirrups on the underside to wheel the carriage platform around the racers. The big pulley at the back of the carriage platform- for pulling the gun back, is turned from aluminium and rotates on a .5mm cross shaft.
Dress pins, NS wire hoops, brass straps, and brass square washers are used for the ironmongery. I got hemp rigging rope from a boat model shop, .5mm for the ropes and .25mm for the flagpole sheet (that's a rope in English).
I cannot tighten up the ropes as the anchor rings are not yet glued in, the painting and stone work has to be completed so they'll be coming out again.
I really enjoyed putting this together, it reminded me of my boat modelling days- also I had loads of time to imagine the guys way back on duty in the tower and how they would crew the gun on top. It must have been a mad job- though shooting the cannon would be fun!
Just need a few cannon balls, powder keg, a ball stuffer, barrel cleaner, and a few cleats to tidy away the ropes and the cannon instillation is complete.
Eoin
  • 4 weeks later...
Volume 1 = http://irishrailwaymodeller.com/showthread.php/2346-murrayec-s-Projects?p=47583&viewfull=1#post47583
Volume 2 = http://irishrailwaymodeller.com/showthread.php/2346-murrayec-s-Projects?p=50850&viewfull=1#post50850
Hi All
Just got a chance today to solder together the bell-crank, tie rods and drive crank for one cylinder on the Hibernia test model, I'm setting up one side of the bell-crank drive system to check sizes and work out the bushings, bolts fixings and the cross-head construction.
Here is a few shots
You can see how they were soldered together here;-
Eoin
Edited by murrayec
Broken Link Fixed
Hi All
I got the bell-crank components cleaned up and assembled to show it off at the MRSI O Gauge Guild meeting today, both were good fun- thanks guys for the invite and been looked after with sandwiches and tea. Good to meet Warbonnet to.
To my amazement the whole assembly worked, a few small adjustments will be needed but it proves the drawings, and it will actually work!
The bell-cranks are fixed with a brass BA screw through crank-pin bushings housed in a milled aluminium bell-crank head mounted on the chassis behind the steam cylinder. The drive rod to the wheel is BA bolt fixed, this bolt runs under the chassis to the inside bell-crank and the rod is fixed between on a brass bushing. The tie-rods are steel riveted onto the bell-crank ends and BA screw fixed to the cross-head- this allows for the whole assembly to be dismantled when in the service shop or the painting department. The location of the drive pin hole on the Slaters wheel had to be adjusted by 1.8mm toward the hub and the existing filled with epoxy. The cross-head rods are 1mm steel rod, so is the con-rod with broached out BA bolts to replicate a big end- if I can call it that?
With that test done its now time to consider the brass chassis, the weight on the plastic is distorting things a bit, the only thing holding this back is the furnace & boiler! I would like to mock them up on the plastic chassis first to see what implications they have on it.
Here are a few shots of the work- the gaffer and crew are also been introduced!
Eoin
  • 3 weeks later...
Very impressive - will join the queue following its progress!
By the by, Agenora models are soon to release a kit of an Aveling & Porter geared engine [7mm scale], with full working motion, flywheel etc. Looks right up your street.
Hi David
Yes an interesting looking engine. Life is strange- I was looking through a railway book the other night and noticed this engine in the background of a photo, its fly-wheel, circular door and narrow cab caught my eye! Then I see your post today...
Eoin
.... here is something further- does this count?;-
[ATTACH=CONFIG]13464[/ATTACH]
[ATTACH=CONFIG]13465[/ATTACH]
Do they go up to "11"?
  • 4 weeks later...
  • 5 months later...
Hi
I'm converting an Oxford Daf 105 Skeletal Trailer Freightliner to the Faller System and here's my take on it, with help from friends and the internet.
After getting the Faller Truck conversion kit and sizing things up it was decided to make some replacement parts for the front axle as the Faller system is for HO- 6mm scale difference in width! Also the Oxford Daf weighs far more than the plastic HO Faller trucks and the plastic axle beam would take on a droop over time. In the photos part of the Faller beam is shown in front of the new fabricated axle beam to give an idea of the scale difference.
There is a 2.5mm diameter difference between Faller and Oxford wheels so it was decided to use Faller throughout. Also, install the load carrying axles in roller bearings to reduce friction and help with the weight (not in the kit) including the trailer, the drive axle is mounted in copper bush bearings supplied with the conversion kit. The side photo shows the scale of the wheels, and without the Oxford wheels in the view- sure it's grand!
Lumps of metal were removed from the chassis, cut-outs were made for the steering through the sides, the reed switch (the brakes), and the horizontally mounted 3V motor and drive gear. A brass plate was made to support the front axle and to hold the front of the chassis in place;- the Oxford chassis has free air where the axle beam needs to mount! ...
So far so good;-
Motor goes in next -that needs to be worked out!, and some mods need to be done to the cab for the battery, then a bit of wiring and..........
Eoin
Edited by murrayec
