IRISH SEMAPHORE SIGNALS
heirflick
How's the men?  Question for ye that I need a bit of help on.  Going back to the days of the beautiful semaphore signals, which made the railways more alive - I can only remember the signal posts being a round post, with the only exception I saw wad at Malahide signal cabin.  Mullingar were all round, as was Edgeworth town and Longford.  Was there square posts used around the net?  Pics please if possible and many thanks in advance,  Seamus
On 7/3/2020 at 6:24 PM, Jon Fitness said:
First post on here! I'll be honest and admit, I'm not modelling Irish railways myself but I do build rather a lot of signals in 7mm scale. I have very happy memories of touring the CIE system back in the 80s and 90s when there were many and wonderful semaphores about. Courtesy of a Tyrconnel Models etch, this is my take on a typical stop signal. It's servo operated and LED lit, using the 5v feed (plus a 330ohm resistor) to the servo to power the led.
Cheers
Jon F.
They are seriously tasty.
9 hours ago, DiveController said:
The SSM kit does three for only 20 euro but they're neither lit nor motorized I believe. Cosmetically they're a nice option. I think someone did a motorized one in OO I believe with 'bounce' and everything but I don't recall
I suppose, like me, you have to build to your own specific needs using what bits are available..
Hi Kevin - DAPOL do 00 signals, motorised and lit.
I have half a dozen of their GWR lower quadrant ones sitting un-installed in a box. They now do brackets as well (NOT CHEAP).
I bought a Ratio signal kit to butcher and use as a non-working platform starter for Richhill - nothing will happen for months, of course, as my left arm is in plaster after a fall.
Des's signals looked decent to me when he was demo-ing them at a Cultra event - wrong railway for me, of course!
I think this is my one thousandth post  - does my rating go up - or DOWN?
WATCH OUT FOR POTHOLES WHEN WALKING IN ENGLAND - IRISH ROADS ARE MUCH BETTER MAINTAINED!
Keep well everyone.
Leslie
Edited by leslie10646
@leslie10646
Thanks for the info Leslie.
You gotta look down from the semaphore observations occasionally or this is what happens (Get Well Soon)
PS
Is that arm in an upper quadrant or a lower quadrant plaster? ..... somersaults, well you did those already 😁
The arm is very much in the DANGER position - whether it's upper, lower or somersault!
As we Ulstermen say "ya cuddn't  mak' it up".
I certainly don't recommend it - but it is suitably humbling and reminds me of how blessed I am compared with others who have to deal which much worse handicaps
Leslie, sorry to hear of the fall.   Get well soon.
The discussion has mentioned signal posts: square - wooden and concrete, lattice, round and telegraph poles.   Signal arms: red and white stop signals  and distant signals. The GSR and CIE distant signals were yellow and white until the end of steam.  The steam locomotive head lamps were only indicators to signal men rather than illuminating the way ahead.   With the powerful head lamps on the diesel locomotives and railcars,  as a further safety feature, the reflective material was put on the signal arms and I read somewhere there was a proposal to do away with the oil lamps on the semaphore signals.
One detail which has not been mentioned in the discussion is the colour of the spectacle plates, perhaps because it is obvious.   If so I apologise.      On the GSR and CIE the spectacle plates are white.   On the GNR and NCC they are the same colour as the signal,  red or yellow.     In Britain on the GWR and BR they are black.
Sometimes you may see British signals in use Irish layouts.
DSERetc
Hi all
Since we are on things signals branch did any of the Irish railways use rotating points indicators to indicate normal and reverse setting on points.
Please do not call it a signal it isn't, its an indicator, even though it is a ground signal like device.
It could possibly have red and white, red and yellow or red and green disks, or square targets fitted depending on period and type.
It would usually be seen on the left side from the facing direction though there where the odd exceptions when it was on the right.
regards John
16 minutes ago, Buz said:
Hi all
regards John
Not rotating, but I presume this is a points indicator at Ballybrophy - in 2008 - all gone now.
There was still a ground frame there then.
Edited by Broithe
Hi Broithe
My guess on it would be a no that's a shunt signal, my reasoning the pattern of lights and head shape is wrong for point indicator.
The light colours and pattern match what I would expect from a ground shunt being two lunar white lights and a colored hard to tell at black out but the bottom left light appears to be red which I would expect on a shunt signal but not on modern point indicator lights.
regards John
On 8/29/2020 at 1:10 PM, Buz said:
Hi all
regards John
Yes, they were used. A late remaining example was on the trap points from the yard at Gort. They tend to be identified on diagrams by having the same lever number as the turnout they are with.
Thanks that means my known reality departure for operational reasons will be at least be believable a catch point indicator and local Mck and H ordinary points indicators with 1896 aspects provided they can be made to work.
regards John
Answer this question...
