Vlak Posted January 18, 2021 Posted January 18, 2021 Something which seems to, perhaps, have been overlooked in terms of freight are the Jumbo Tar Wagons. These were 2-Axle wagons which were used for the conveyance of Bitumen to both Sligo (and possibly Galway?) for Cold Chon. They were loaded in Alexander Road at their Tar Terminal and usually added to liner trains for the run west. Based on what little information I can gather the traffic didn’t really amount to much more than 3-6 wagons per train at a time. The traffic flow seems to have ended around 2001/2, although the bogie wagons (which contained ISO Bitumen containers which were used to Mallow for Council use) seems to have lasted into until 2003/4. It has been challenging to find photographs of these wagons in detail, other than a few photos with them in the background, but they appear to have been constructed / modified by CIE using Bitumen tanks mounted on short wheelbase 20ft flats (same as the Cement Bubbles it would seem) with the same tank anchors as was the case for most fuel oil & latterly Esso Oil wagons. Two tank designs appear to have been in use, one with a flat end and another with a more rounded end with ribs. I attach two screen shots taken from the video linked below which provides a little more detail (hope the author of the video doesn’t mind!); it would seem that unique to tank wagons here the ladders were positioned at the end of the tank rather than in the middle. I would also hazard a guess the reason they gained the name ‘Jumbo’ was due to their larger more bulky tank design in comparison to the oil tanks to account for the lagging. Video of a typical formation for Jumbo Tar Tanks: Further discussion / information or even photos & drawings welcomed. 4 1
flange lubricator Posted January 18, 2021 Posted January 18, 2021 Found this on in Wexford County Council Yard in Ballycullane in 2004 2
popeye Posted January 18, 2021 Posted January 18, 2021 Never seen these before, and Molasses tanks are rare too. I often wondered what was Molasses used for?
flange lubricator Posted January 18, 2021 Posted January 18, 2021 (edited) Dont think that the Same Wagon Wrenneire the jumbo wagons were insulated which made them look big . Edited January 19, 2021 by flange lubricator 1
Mayner Posted January 18, 2021 Posted January 18, 2021 I did not realise that IE used the "Tar Wagons" during the 1990s as tar traffic was transported in ISO tank containers after CIE went over to Liner Train operation during the late 70s. There is a photo feature on private sidings in the February 2019 Journal which includes photos of operations at a number of sidings which handles tar traffic including Sligo Quay, Cahir Abbey Siding, Webbs Mill (Mallow) & Lixnaw. The "Jumbo" Tar wagons look suspiciously like an insulated version of the re-gauged Charles Roberts tank wagons imported by ESSO Teo from the UK during the late 60s. There is a reasonable photo of one of these wagons at Cahir and a more distant view of a pair at Sligo Quay. A number of these wagons were stored out of use for many years at the Point Yard after the ending of loose coupled traffic and brought back into use with the re-opening of Sligo Quay during the 1990s, presumably ESSO/Cold Chon were able to negotiate a lower freight rate with IE for using their own wagon than an ISO tank container and IE wagon. The Heljan or Dapol ESSO type A tank wagons would be a good basis for these wagons though the body would need serious modification, Bachmann appear to produce a model of a 45T BR tar tank wagon which is quite different design and larger than the ESSO Teo Tar Tank wagons. Over the fence view of out of use ESSO "Jumbo" Tar Wagon at North Wall Point Yard c. 1982-3. I was more interested in the Mex tank wagon at the time. A number of the Jumbo tank wagons were stored/dumped in the Dardanelles Yard by the Sheriff St level crossing until the yard was cleared out c2002 1
fishplate7 Posted January 20, 2021 Posted January 20, 2021 On 18/1/2021 at 1:42 PM, Vlak said: Something which seems to, perhaps, have been overlooked in terms of freight are the Jumbo Tar Wagons. These were 2-Axle wagons which were used for the conveyance of Bitumen to both Sligo (and possibly Galway?) for Cold Chon. They were loaded in Alexander Road at their Tar Terminal and usually added to liner trains for the run west. Based on what little information I can gather the traffic didn’t really amount to much more than 3-6 wagons per train at a time. The traffic flow seems to have ended around 2001/2, although the bogie wagons (which contained ISO Bitumen containers which were used to Mallow for Council use) seems to have lasted into until 2003/4. It has been challenging to find photographs of these wagons in detail, other than a few photos with them in the background, but they appear to have been constructed / modified by CIE using Bitumen tanks mounted on short wheelbase 20ft flats (same as the Cement Bubbles it would seem) with the same tank anchors as was the case for most fuel oil & latterly Esso Oil wagons. Two tank designs appear to have been in use, one with a flat end and another with a more rounded end with ribs. I attach two screen shots taken from the video linked below which provides a little more detail (hope the author of the video doesn’t mind!); it would seem that unique to tank wagons here the ladders were positioned at the end of the tank rather than in the middle. I would also hazard a guess the reason they gained the name ‘Jumbo’ was due to their larger more bulky tank design in comparison to the oil tanks to account for the lagging. Video of a typical formation for Jumbo Tar Tanks: Further discussion / information or even photos & drawings welcomed. On 18/1/2021 at 1:42 PM, Vlak said: Something which seems to, perhaps, have been overlooked in terms of freight are the Jumbo Tar Wagons. These were 2-Axle wagons which were used for the conveyance of Bitumen to both Sligo (and possibly Galway?) for Cold Chon. They were loaded in Alexander Road at their Tar Terminal and usually added to liner trains for the run west. Based on what little information I can gather the traffic didn’t really amount to much more than 3-6 wagons per train at a time. The traffic flow seems to have ended around 2001/2, although the bogie wagons (which contained ISO Bitumen containers which were used to Mallow for Council use) seems to have lasted into until 2003/4. It has been challenging to find photographs of these wagons in detail, other than a few photos with them in the background, but they appear to have been constructed / modified by CIE using Bitumen tanks mounted on short wheelbase 20ft flats (same as the Cement Bubbles it would seem) with the same tank anchors as was the case for most fuel oil & latterly Esso Oil wagons. Two tank designs appear to have been in use, one with a flat end and another with a more rounded end with ribs. I attach two screen shots taken from the video linked below which provides a little more detail (hope the author of the video doesn’t mind!); it would seem that unique to tank wagons here the ladders were positioned at the end of the tank rather than in the middle. I would also hazard a guess the reason they gained the name ‘Jumbo’ was due to their larger more bulky tank design in comparison to the oil tanks to account for the lagging. Video of a typical formation for Jumbo Tar Tanks: Further discussion / information or even photos & drawings welcomed. Hi Vlak. My video! Yep, no problem at all using it. That's what they are there for! Interesting topic too! Cheers. Eamonn
fishplate7 Posted January 20, 2021 Posted January 20, 2021 Here is another example of the same wagon. Scroll to 8.05 on the video. 4
Robert Shrives Posted January 20, 2021 Posted January 20, 2021 https://www.oliviastrains.com/trains/mt/bachmann-wagons/bachmann-tank-wagons/bachmann-37-560-45- This looks about right but not yet at market Robert 1
murphaph Posted January 20, 2021 Posted January 20, 2021 Did they in fact go to Galway or just Sligo?
Robert Shrives Posted January 20, 2021 Posted January 20, 2021 Sligo (Cold Chon )- upto 2002 when it closed. Was a main point but pictures do show individual wagons on other lines - County road repair depots . Cannot find a pic straight away in books to hand internet trawling might gain something. 1
Mayner Posted January 21, 2021 Posted January 21, 2021 The ESSO Teo Bitumen tank wagons appear to have been re-gauged from ESSO 22T Bitumen wagons built in the late 1950s rather than the 45GLW type like the Bachmann model which would have been too heavy to run in Ireland There is a good selection of photos on ESSO 22T Bitumen Tank Wagons in their original condition in https://paulbartlett.zenfolio.com/essobitumenvb. Many of the UK tanks were re-built with revised running gear and tank mounting. Railborne bitumen traffic to Cold Chon Sligo was a short lived 90s revival, IE discontinued bitumen traffic by individual wagon load during the mid 1970s transporting the traffic in ISO containers with road transfer to distributors such as Cold Chon, Irish Tar and Bitumen and Council Depots. Esso Teo appears to have stored its relatively modern (by Irish standards) 22T Bitumen tankers which appear to have been re-used when the Sligo quayside siding was re-opened during the 1990s. Oranmore was the rail head for Bitumen, Oil and Scrap Metal traffic in the Galway area until the sidings were disconnected in the late 70s, bitumen and scrap transported by Liner Train in ISO containers with a road transfer from Galway, ESSO oil traffic apparently transferring to coastal shipping. Oranmore would have been interesting in wagon load days Chold Chon used a Scammell Road road tractor on rail wheels as a year shunter. 2
Robert Shrives Posted January 21, 2021 Posted January 21, 2021 John, What took me to the 45t version was the end ladder arrangement. But I can make out from the stills is that one wagon, like the landed tank has a conical end the others look more domed but all have the twin fire tubes and top vent. An interesting wagon . A pic of a bitumen ISO tank would be good to see. Thanks for the potted history of the freight flow, better than I could put it Robert
Mayner Posted January 21, 2021 Posted January 21, 2021 Traditionally Tar/Bitumen was transported in 45gal drums in open wagon on the Irish Railway system with CIE 1st introducing tank wagons for tar traffic in the 1950s. The Florencecourt and Glenfarne on the SLNCR appear to have the railheads for the local County Council depots. In most photos of Glenfarne the loading bank is literally covered in tar barrels, while there is a cut of 4 opens with tar traffic awaiting unloading in a photo of Florencecourt. A series of County Council & CIE depots were opened in the early 1960s to handle tar traffic. Some of the Council depots such as Cahir (Abbey Siding) & Lixnaw were served by private siding while other depots were in existing CIE goods yards Ballingarne and Tralee Rock Street. There is an interesting sequence of photos of the Tralee-Listowel goods setting out a CIE tank wagon, including the loco and train propelling the wagon along the main line from Lixnaw Station to the County County Siding. In the 1950s CIE bought several batches of Tar Tank wagons from Charles Roberts these were similar in appearance to the Bachmann 14T Anchor Mounted Tank Wagons but with an insulated tank barrel https://www.bachmann.co.uk/product/14t-class-a-anchor-mounted-tank-wagon-'national-benzole'/38-778. These wagons seem to have been based on a standard RCH design complete with independent either side brakes unusual in Ireland but standard practice for private Owner Mineral and Tank wagons on the UK Mainland. CIE started to build Tar Tank wagons during the early 60s on a standard Irish underframe with Irish style brake gear but an anchor mounted barrel similar to the Charles Roberts wagons. I think the "Jumbo" wagons may have been modified ESSO 22T Bitumen Tankers the ladders moved to the ends because of increased thickness of insulation. Wagon 997 in the late 1970s IRRS Journal photo appears to be a TSO34A wagon with domed ends and original tank mounts as in https://paulbartlett.zenfolio.com/essobitumenvb The ladder position on the wagons in the Sligo Deepwater Quay 1995 photo in the same journal is unclear. The 22.5ton axleload of 45GLW UK tank wagons would have substantially exceeded CIE axleload limits, the Sligo Deepwater branch was re-laid to 23826 is an out of use CIE built wagon, not sure of the location although I took the photo one of the few remaining loose coupled wagons that survived into the 80s. The ISO Bitumen Containers were a standard insulated framed containers similar to https://www.meeberg.com/en/new-products/bitumen/20-ft-bitumentank/. Its possible the containers were privately owned or supplied by CIE. The containers were allover black with panels in the bracing bays at one end with product details. From memory the details were "Cationic Road Emulsion and Cut Back Bitumen" in large black lettering on a yellow or orange background above smaller orange or white lettering on black panels possibly with supplier details. As a rule is that from the mid-1950s to the end of loose coupled working in the late 70s bitumen was transported in individual wagons loads (often 1 wagon!) to private sidings and CIE goods yards in Charles Roberts built wagons similar to The Bachmann 14T anchor mounted tank wagon or CIE built wagons. ESSO appears to have imported a small number of 22T Bitumen tank wagons when it modernised its wagon fleet in the late 60s, the ESSO 22T wagons appear to have run as individual wagons loads to destinations including Cahir on the Waterford-Limerick line in addition to the North Wall Sligo Oil trains. Bitumen Traffic by individual wagons load appears to have ceased in 78 with the closure of rail served depots such as Cahir, Ferns, Lispole, Oranmore and Sligo Deepwater Quay. Wagon load traffic to Cold Chon at Sligo Deepwater Quay was revised in the mid 1990s but may have ceased by 1999 and the Deep Water Quay line lifted in 2002. Although intended to operate as de-mountable the Bitumen containers seem to have been treated as wagons both loading and discharging on the rail, they usually seem to have been mounted on 20' skeletal flats, with several seemingly dumped for many years in the Dardanelles Sidings before the yard was cleared out in the early 2000. An interesting place but difficult to take a decent photo. Two bitumen containers just about visible on 4w flats in the Dardanelles Sidings during the late 90s. At the time I was more interested in 113 an early 160s Texaco Class A tank wagon, the original Caltex lettering had bled through after the wagon was re-branded. A rake of these wagons was used on the North Wall Inchacore fuel oil train until replaced with CIE stores wagons in the late 70s possibly the last loose coupled good train in the Dublin area. 1 1
Galteemore Posted January 21, 2021 Posted January 21, 2021 John - quite right re Glenfarne and Florencecourt. This was especially so during the summer I think. Any ideas where such traffic may have originated ? Am assuming it was from Dublin/Belfast and carried in GN/CIE wagons with no transshipment, but will be hunting out that Florencecourt photo. I have a wagon load of drums for Rosses Point - much as I’d like to use an SLNC wagon for that it strikes me as unlikely and I should probably provide a CIE open.
airfixfan Posted January 21, 2021 Posted January 21, 2021 (edited) The County Donegal csrried oil in tank wagons from the port in Derry to the fishing boats at Killybegs in particular. Edited January 21, 2021 by airfixfan
Mayner Posted January 21, 2021 Posted January 21, 2021 2 hours ago, Galteemore said: John - quite right re Glenfarne and Florencecourt. This was especially so during the summer I think. Any ideas where such traffic may have originated ? Am assuming it was from Dublin/Belfast and carried in GN/CIE wagons with no transshipment, but will be hunting out that Florencecourt photo. I have a wagon load of drums for Rosses Point - much as I’d like to use an SLNC wagon for that it strikes me as unlikely and I should probably provide a CIE open. Most likely in GNR wagons from Dublin, Belfast or possibly Derry Port's as Airfixfan pointed out the CDJR tank wagons were used to transport oil traffic from Derry to Killybegs and other points on the system. Its possible tar traffic for Glenfarne was imported through Dublin Port and routed via Dundalk and Enniskillen rather than via Mullingar. The SLNCR & the GNR competed seriously with the GSR and CIE for traffic from the Dublin and the East Coast to Sligo. Its just about possible that a wagon load of tar or bagged cement might arrive in Rosses Point in a GN wagon having travelled under customs bond through County Fermanagh 1
TimO Posted January 21, 2021 Posted January 21, 2021 There was also a tar/ bitumen unloading facility in the Conniberry sidings in Portlaoise. The Laois County Council tar lorries used to reverse into the building below rail level to be filled. The building still exists. It was certainly used in the 70’s and there were regular fires, presumably from leaking bitumen. Does anyone know how the heating coils were kept warm in traffic or were they only connected in the depots?
dave182 Posted January 10, 2023 Posted January 10, 2023 Just revisiting this topic, as I've recently got my hands on IRRS Journal 198 thanks to Iarnrod of this parish. The article on Private Sidings by Ciarán Cooney features some great photos of bitumen wagons at Lixnaw, Quartertown and ColdChon Sligo and Galway. I'm looking for information about the unloading of bitumen at the Sligo Cold Chon depot at the end of Deepwater Quay. Did the line run into the Cold Chon premises, or was there some way of unloading the bitumen on the quayside? I've reviewed historical maps but they are very inconclusive. The Cahir Abbey siding is interesting too. Again, any information on the white building pictured would be very helpful. Did it have bitumen tanks inside and heating equipment? How was the rail tank unloaded, and how were the council trucks loaded?
The Derry Road Posted January 11, 2023 Posted January 11, 2023 On 18/1/2021 at 2:31 PM, popeye said: Never seen these before, and Molasses tanks are rare too. I often wondered what was Molasses used for? here is one i made up some years ago TDR 4
DJ Dangerous Posted December 6, 2024 Posted December 6, 2024 So, would the new IRM / Heljan Esso chassis also suit Tar tanks?
Mayner Posted December 7, 2024 Posted December 7, 2024 (edited) 11 hours ago, DJ Dangerous said: So, would the new IRM / Heljan Esso chassis also suit Tar tanks? Oil and Bitumen tanks appear to share the same chassis. I suppose the question is whether its worth while replacing/increasing the diameter of the existing tank, or there is enough potential demand for a manufacturer/retailer to commission a RTR version of an ESSO Bitumen Tank wagon. Visually there is not a lot of difference between the two types. Grungy coat of black to may be the simplest Bitumen tank conversion option. 998 is the no of the one in the IRRS Cahir Abbey photo same tank mount original tank mounts as the Paul Bartell photo https://paulbartlett.zenfolio.com/essobitumenrebuilt https://paulbartlett.zenfolio.com/essoatankwagonvb Some wagons appear to have run in the UK without ESSO shields ands significant spillage so not just a CIE/IE thing. https://paulbartlett.zenfolio.com/essoatankwagonvb Edited December 7, 2024 by Mayner 1
Mol_PMB Posted April 17 Posted April 17 The HMRS archive has some nice views of the Tar Bitumen tanks built by Charles Roberts, when new. Here's 23855 when new in 1954: [AAT037] 15T tank CIE 23855, 5' 3"gauge loaded on Flatrol 168964, ex-Works. For Tar / Bitumen traffic. 25002 in 1962: [AAU529] 14T tar bitumen tank CIE 25002 on Flatrol [OP] Chas Roberts yard 25018, also in 1962, view of the other side: [AAU532] 14T tar bitumen tank CIE 25018 on Flatrol [OP] Chas Roberts yard 2
Mayner Posted April 17 Posted April 17 (edited) The 'Jumbo Tank' wagons with domed ends built for Irish Shell BP tar traffic in 1972 appear to be something of a mystery with no running numbers or number of wagons built in the magazine article and apart from 26729 an otherwise watertight wagon number series of tank wagons between 26723-26728 (Burmah 5000Gal 1972 ) & 26730-26740 (4500Gal 1978) The fact that bitumen tanks of the same design exist at Ballyculane & Ferns and the magazine article writing about a fleet of wagons indicates that CIE built more than one Jumbo Tank with domed ends. Interestingly both Ferns & Wellington Bridge (serving Ballyculane) had closed to railborne tar traffic during the mid 1970s its just about possible that the Bitumen tank wagons may have occupied the 26729-26740 number series. The 'modern' CIE Bitumen tank wagons were similar in general outline to the 4w 35GWT tank wagons introduced on BR during the 60s though shorter, 'back in the day' about 1980! I shortened a Peco N Gauge 35GWT tank to resemble a Burmah tank wagon & one of the UK finescale mags featured an article om converting the Hornby 35GWT Tank Wagon into a bitumen tanker mainly by re-painting and weathering. The 'Jumbo Tank Wagons' in the video appear to be the ESSO variety with domed tank ends. There is an interesting series of 1976 photos in Rails Through North Kerry JHB & Barry Carse 2016 of 023 shunting/working 23855 (1950s Inchacore built Bitumen Tank wagon between Lixnaw Station and the Co Council depot. Edited April 17 by Mayner 2
jhb171achill Posted April 17 Posted April 17 50 minutes ago, Mayner said: The 'Jumbo Tank' wagons with domed ends built for Irish Shell BP tar traffic in 1972 appear to be something of a mystery with no running numbers or number of wagons built in the magazine article and apart from 26729 an otherwise watertight wagon number series of tank wagons between 26723-26728 (Burmah 5000Gal 1972 ) & 26730-26740 (4500Gal 1978) The fact that bitumen tanks of the same design exist at Ballyculane & Ferns and the magazine article writing about a fleet of wagons indicates that CIE built more than one Jumbo Tank with domed ends. Interestingly both Ferns & Wellington Bridge (serving Ballyculane) had closed to railborne tar traffic during the mid 1970s its just about possible that the Bitumen tank wagons may have occupied the 26729-26740 number series. The 'modern' CIE Bitumen tank wagons were similar in general outline to the 4w 35GWT tank wagons introduced on BR during the 60s though shorter, 'back in the day' about 1980! I shortened a Peco N Gauge 35GWT tank to resemble a Burmah tank wagon & one of the UK finescale mags featured an article om converting the Hornby 35GWT Tank Wagon into a bitumen tanker mainly by re-painting and weathering. The 'Jumbo Tank Wagons' in the video appear to be the ESSO variety with domed tank ends. There is an interesting series of 1976 photos in Rails Through North Kerry JHB & Barry Carse 2016 of 023 shunting/working 23855 (1950s Inchacore built Bitumen Tank wagon between Lixnaw Station and the Co Council depot. Barry and I discussed this at length when selecting pictures for that book. I was completely unfamiliar with them at the time. Haven't seen much about them since, and that book is now out of print!
Mayner Posted April 18 Posted April 18 1 hour ago, jhb171achill said: Barry and I discussed this at length when selecting pictures for that book. I was completely unfamiliar with them at the time. Haven't seen much about them since, and that book is now out of print! The wagon in the Lixnaw photos was basically the Inchacore version of the 1952 & 62 Charles Roberts featured in MOL_PMB recent post. The Inchacore built wagons appear to have been built on a 'Standard Irish' steel underframe as opposed to a British RCH tank wagon underframe. I used the tanks from the IRM Weedkiller Train set with my own 3D printed wagon Chassis, but decided it was not worth the hassle of trying to fit the lagging to the tanks. I guess Bitumen tanks based on the recent IRM Fuel Tank wagons would pass the 2' test or possibly the Bachmann anchor mounted tanks 2
Mol_PMB Posted April 18 Posted April 18 For the early, flat-ended unfitted type in the HMRS (Charles Roberts) photos and the post immediately above, I have the following number series: 23801-23845 (built 1953), 17'6" LOH, 15t capacity 23851-23890 (built 1954), 17'6" LOH, 15t capacity 25001-25020 (built 1962), 17'6" LOH, 15t capacity Here's a photo of 23805: https://www.flickr.com/photos/irishrailwayarchive/54251527038 and here's 23829: The bulbous-ended bitumen tanks built for Shell were as follows: 501-510 (built 1971-2), 20' LOH, 13t tare, 18.5t capacity Here is 506, newly built at Inchicore: https://www.flickr.com/photos/irishrailwayarchive/53511632099 They appear to have been rebuilt from 20' container flat wagons and still retain their ISO spigots on the corners of the underframe. However, the photo above also shows an RCH private owner wagon registration plate on the solebar, which proves that these tank wagons were privately owned rather than CIE-owned. This would explain why they weren't in the CIE number series. Then there were the ones with conical ends to the cladding, I think these belonged to Esso and there some information on them up-thread. I assume they were numbered in the Esso tank series 971 to 1013. 1
Mayner Posted April 18 Posted April 18 3 hours ago, Mol_PMB said: The bulbous-ended bitumen tanks built for Shell were as follows: 501-510 (built 1971-2), 20' LOH, 13t tare, 18.5t capacity Here is 506, newly built at Inchicore: https://www.flickr.com/photos/irishrailwayarchive/53511632099 They appear to have been rebuilt from 20' container flat wagons and still retain their ISO spigots on the corners of the underframe. However, the photo above also shows an RCH private owner wagon registration plate on the solebar, which proves that these tank wagons were privately owned rather than CIE-owned. This would explain why they weren't in the CIE number series. Then there were the ones with conical ends to the cladding, I think these belonged to Esso and there some information on them up-thread. I assume they were numbered in the Esso tank series 971 to 1013. Interesting the two Bitumen Tanks on the Sligo Liner passing Maynooth in the Video in Fishplate 7s Posted January 20, 2021 appear to be numbered in the 500 series although they appear to have domed tank ends and at least one of the Bitumen Tanks on the Sligo Liner in Valk's initial post appears to have domed ends indicating that its possible that some the Shell BP Bitumen Tank Wagons survived at least until Bitumen traffic ceased. The Burmah, CIE Fuel Oil tank wagons introduced during the 1970s ran on the "Standard" CIE 20' Skeletal Underframe complete with ISO spigots appear to have been considered new builds presumably in addition to the 300 27101 series flats, while the 26730-26740 series Tank Cars introduced 1978 apear to have been classed as conversions of the 27101 Flats which had largely become surplus to requirements with the introduction of the 22'6" Flats and large nos of Bogie Flats. 1 1
Railtank Posted December 10 Posted December 10 On 18/1/2021 at 2:30 PM, flange lubricator said: Found this on in Wexford County Council Yard in Ballycullane in 2004 Anyone know if this barrel and chassis still survives ?
