Noel Posted June 19, 2016 Posted June 19, 2016 Are either of the two preserved locos 124 or 134 in operational condition? Quote
Railer Posted June 19, 2016 Posted June 19, 2016 No, the 124 in ITG hands has little hope of running again. 134 has yet to be assessed by the RPSI until it is moved to Connolly shed along with 141 and 175. 134 has the best chance of seeing action again but it will be long, long time coming. Quote
Horsetan Posted June 20, 2016 Posted June 20, 2016 No, the 124 in ITG hands has little hope of running again. .... That's interesting. Is that because 124 is "too far gone" / not economically viable to run, or because the ITG doesn't have the resources? Quote
Railer Posted June 20, 2016 Posted June 20, 2016 The ITG have no plans to run 124 at all and it's intended to just be used as a museum display piece when that gets built. It's a shame as they have acquired the last Mk3 PP driving trailer and cafe/bar coach which would have been ideal for 124 to haul on the DCDR. Quote
Noel Posted June 20, 2016 Posted June 20, 2016 Thanks guys for the feedback. It's a shame there are no preserved lines in ROI that heritage stock could be run on, even a segment a few miles long from a closed line. Ballybrophy to Limerick must be at risk of closure, hope it doesn't but if it did, it might be an opportunity for a well funded preservation movement along with some state grand aid, to preserve and operate a short section of the former line. Ballybrophy has the advantage that folks could travel to the heritage line by rail and just walk across the platform. Probably pie in the sky, as here in ROI we do not have a culture of state aid and support for such projects unlike the UK and NI. Quote
Tarabuses Posted July 31, 2016 Posted July 31, 2016 There is going to be a problem creating a sound decoder for the 121 if there is no loco running. Quote
Warbonnet Posted July 31, 2016 Posted July 31, 2016 There is going to be a problem creating a sound decoder for the 121 if there is no loco running. Do they sound any different to a 141? Quote
Noel Posted July 31, 2016 Posted July 31, 2016 Do they sound any different to a 141? Existing Zimo and Locsound 141 sound projects should be close enough for a model Quote
DiveController Posted July 31, 2016 Posted July 31, 2016 Existing Zimo and Locsound 141 sound projects should be close enough for a model Noel, who does those Zimo project? I think Mr. Soundguy does the Loksound but there have been some issues using the Loksound 4.0 decoder with ABC signaling. I'm glad I became aware of it before investing Quote
enniscorthyman Posted July 31, 2016 Posted July 31, 2016 Mr sound guy uses Zimo sound chips now. A good few years ago he did use the ESU chips sold through DCC supplies.He sells direct now via his own site. Quote
NIRCLASS80 Posted July 31, 2016 Posted July 31, 2016 Just recently ESU loksound have upgraded lots of there GM engine sound files for the american market. I took one and edited it to include irish 071 horn sound file and it sounds great with the new feature called full throttle. Sadly I cannot video it as I am in the middle of a house move but as soon as I get a chance I will. I think you will like it and the engine sounds are also available for the 121's. Quote
DiveController Posted August 1, 2016 Posted August 1, 2016 Mr sound guy uses Zimo sound chips now.A good few years ago he did use the ESU chips sold through DCC supplies.He sells direct now via his own site. Thanks, Eamonn. Much appreciated. Just recently ESU loksound have upgraded lots of there GM engine sound files for the american market. I took one and edited it to include irish 071 horn sound file and it sounds great with the new feature called full throttle. Sadly I cannot video it as I am in the middle of a house move but as soon as I get a chance I will. I think you will like it and the engine sounds are also available for the 121's. Many thanks, NIR. Will look forward to that whenever possible. Quote
NIRCLASS80 Posted August 1, 2016 Posted August 1, 2016 The great thing about using ESU common sound files is that you don't have to pay for each loco's sound file. You can simply load it into the chip using the ESU Lokprogrammer and even update and modify the sound according to your needs. Quote
DiveController Posted August 1, 2016 Posted August 1, 2016 (edited) The great thing about using ESU common sound files is that you don't have to pay for each loco's sound file. You can simply load it into the chip using the ESU Lokprogrammer and even update and modify the sound according to your needs. Does this just give you greater access to customize the sound chips and does it make equipping ones fleet with sound any cheaper? Incidentally, without getting too far off tread, I have a Bachmann Class 20 with a Loksound 4.0 which has an excellent sound for the Hunslet motor but I need some horns other than the BR ones. If anyone can suggest suitable files, I'm happy to get a Lokprogrammer. Thanks Edited August 1, 2016 by DiveController Quote
Noel Posted August 2, 2016 Posted August 2, 2016 Does this just give you greater access to customize the sound chips and does it make equipping ones fleet with sound any cheaper? . . . Having initially been impressed and very enthusiastic about DCC sound, I have changed my own view about equipping a 'fleet' of model locos. I've found that running more than one sound equipped loco at the same time doesn't actually sound great, instead rather a confused noise blurred into one indistinctive 'din'. Also simulated 'doppler' effect not currently possible with DCC sound. The distant rumble of a GM loco and horn was very unique as was coasting 'rail' noise. So just personally speaking I won't aspire to fitting DCC sound to more than a few 'party piece' models including one of the existing 141 sound chip in a 121 when they become available. The concurrent sound issue seems a bigger barrier than cost. Quote
Dhu Varren Posted August 2, 2016 Posted August 2, 2016 Incidentally, without getting too far off tread, I have a Bachmann Class 20 with a Loksound 4.0 which has an excellent sound for the Hunslet motor but I need some horns other than the BR ones. If anyone can suggest suitable files, I'm happy to get a Lokprogrammer. Thanks Unfortunately, the Lokprogrammer cannot alter the sound program on a decoder. To make any changes, you need to have the original sound programme, amend it, and reblow the decoder. For GM locos this is easy to do, as NIRCLASS80 says, you can download a suitable sound program from ESU, amend it as required, and load it onto a Loksound decoder. Apart from GM locos, BR locos are not available from the ESU library. Quote
Irishrailwayman Posted August 2, 2016 Posted August 2, 2016 Unfortunately, the Lokprogrammer cannot alter the sound program on a decoder. To make any changes, you need to have the original sound programme, amend it, and reblow the decoder. For GM locos this is easy to do, as NIRCLASS80 says, you can download a suitable sound program from ESU, amend it as required, and load it onto a Loksound decoder. Apart from GM locos, BR locos are not available from the ESU library. Correct. Also, each manufacturer's chip needs different equipment for re-programming. The original soundfiles are owned by the supplier companies. Quote
murrayec Posted August 2, 2016 Posted August 2, 2016 What the LokProgrammer can do: Change the sound saved on the decoder. Setting of all digital parameters of the Loksound decoder such as address of the loco, operation speed, maximum speed, braking deceleration, brightness of bulbs etc; you can set all options with your computer very easily - no cumbersome entering of CVs (configuration variables) with your command station. Rearrange your sounds and transfer it to the LokSound decoder. You can use all sounds that can be downloaded to your computer hard disk. Sound can be allocated to different events. Additional sounds can be activated via function buttons. Sound With the LokProgrammer you can erase the sound data of any LokSound decoder as many times as you wish, and replace it with a different sound. To this end we offer on our homepage more than 200 different, fully matching sounds of various prototypes and locos for downloading on your computer. Also you can edit just parts of a sound project: You don’t like the decoder’swhistle? Just replace it with one of the many others. Suitable sources beside those offered by us, are in Windows *.wav format available. Sound – even voice or music is no problem for our decoders. With the LokProgrammer’s aid you use the entire flexibility and functionality offered by LokSound decoders. Quote
DiveController Posted August 2, 2016 Posted August 2, 2016 What the LokProgrammer can do: Change the sound saved on the decoder. Setting of all digital parameters of the Loksound decoder such as address of the loco, operation speed, maximum speed, braking deceleration, brightness of bulbs etc; you can set all options with your computer very easily - no cumbersome entering of CVs (configuration variables) with your command station. Rearrange your sounds and transfer it to the LokSound decoder. You can use all sounds that can be downloaded to your computer hard disk. Sound can be allocated to different events. Additional sounds can be activated via function buttons. Sound With the LokProgrammer you can erase the sound data of any LokSound decoder as many times as you wish, and replace it with a different sound. To this end we offer on our homepage more than 200 different, fully matching sounds of various prototypes and locos for downloading on your computer. Also you can edit just parts of a sound project: You don’t like the decoder’swhistle? Just replace it with one of the many others. Suitable sources beside those offered by us, are in Windows *.wav format available. Sound – even voice or music is no problem for our decoders. With the LokProgrammer’s aid you use the entire flexibility and functionality offered by LokSound decoders. I think that is what I want to do, change the whistles which are the problem. The engine sounds great and if I can leave the engine sound in there I'd be happy. I may want to fiddle with CV for momentum etc but that's another issue. Quote
Dhu Varren Posted August 2, 2016 Posted August 2, 2016 I think that is what I want to do, change the whistles which are the problem. The engine sounds great and if I can leave the engine sound in there I'd be happy. I may want to fiddle with CV for momentum etc but that's another issue. Kevin, you can't change just part of the sound installed on the decoder, you have to reblow the whole thing, which means reinstalling ALL the sounds, which means you need a complete Class 20 sound project, which is where you can put in horns/whistles etc. of your choice. Quote
DiveController Posted August 3, 2016 Posted August 3, 2016 Kevin, you can't change just part of the sound installed on the decoder, you have to reblow the whole thing, which means reinstalling ALL the sounds, which means you need a complete Class 20 sound project, which is where you can put in horns/whistles etc. of your choice. ok, understood, David. Thank you for that. But no Class 20 is available as I understand it, so I'm stuck with it. Engine sound only I guess for the Hunslet. Thanks all for your comments and for taking this off thread a little. Back to 121s, no word on the MM website yet, been watching for the commemorative item and the any word on the grey & yellow to appear Quote
Vlak Posted August 3, 2016 Posted August 3, 2016 While sounding similar to the 141s the 121s had a bit more of a 'whine' to them in my experience. This video depicts 134+144 working a laden beet down to Mallow's Beet Factory and then subsequent shunting in very poor rail conditions. You can also hear the knocking at the beginning of the video as the pair build brakes, this is coming from the air compressor on 134. All 121's compressors produced this 'knocking' sound as they were building air / vacuum. While on the subject of the 121s is there any news or updates regarding the 121s or their production? Are we likely to see any pre-production photos or models by the end of the year? Quote
murrayec Posted August 3, 2016 Posted August 3, 2016 Hi In this months Railway Modeller- Rails of Sheffield are advertising an ESU decoder with Class 20 sounds for £89.50. With the LokProgrammer one imports the sound project from the decoder, then changes or adds sounds to the project and then writes the project to the decoder..... Eoin Quote
irishthump Posted August 3, 2016 Posted August 3, 2016 Hi In this months Railway Modeller- Rails of Sheffield are advertising an ESU decoder with Class 20 sounds for £89.50. With the LokProgrammer one imports the sound project from the decoder, then changes or adds sounds to the project and then writes the project to the decoder..... Eoin You can't import a sound file from a decoder. You need to be in possession of the original file. Quote
irishthump Posted August 3, 2016 Posted August 3, 2016 Divecontroller, DC Kits have an excellent range of soundfiles for British locos. They may be willing to write a bespoke file to your specifications if you just want to change a few horn sounds. Might be worth contacting them.... Quote
murrayec Posted August 4, 2016 Posted August 4, 2016 You can't import a sound file from a decoder. You need to be in possession of the original file. That's correct- I installed the system last night to take a look at the software to see, I miss read their sales text! Though you do get a lot of sound projects on the instillation disk which has plenty of diesel locos that can be edited for uploading to a decoder. Eoin Quote
irishthump Posted August 5, 2016 Posted August 5, 2016 That's correct- I installed the system last night to take a look at the software to see, I miss read their sales text! Though you do get a lot of sound projects on the instillation disk which has plenty of diesel locos that can be edited for uploading to a decoder. Eoin Yes, and the website has a large selection of files from various countries which are free to download. No UK outline but there's plenty of US locos which is good if you model Irish! Is there anything there that would work for your DART project? Quote
DiveController Posted August 5, 2016 Posted August 5, 2016 Divecontroller, DC Kits have an excellent range of soundfiles for British locos. They may be willing to write a bespoke file to your specifications if you just want to change a few horn sounds. Might be worth contacting them.... Yes, and the website has a large selection of files from various countries which are free to download. No UK outline but there's plenty of US locos which is good if you model Irish! Is there anything there that would work for your DART project? Eoin and IT, thanks for all of that which has ben immensely helpful Quote
201bhoy Posted December 11, 2016 Posted December 11, 2016 Anyone know what the craic is with the 121s? Seems to have gone very quiet on this front! Quote
Noel Posted April 27, 2017 Posted April 27, 2017 (edited) Word is that a provisional date of Christmas 2016 has been given to the release of the first 121s which will be the first grey and yellow livery and the final IE livery with more to follow in 2017. Corrected Supertrain Mark IIS and 201s in latest livery are also on the way. First, the news everybody has been waiting for. Class 121 CAD drawings were started in December. It is expected that pre-production samples will be available for perusal at the MRSI October Show in Raheny with a first delivery in time for Christmas. It is intended that the IE and original CIE grey will be first to arrive with CIE Black and Supertrain and IR versions to follow within 9-10 months. Oh I'm getting just a shade impatient waiting to operate a 121 model. Had been wondering if pairing one of these . . . . . with one of these might carry me over until MM (Murphy Magic) release a 121? It would be a far cry from the detail and correct precision of an injection moulded MM, but may pass the 'duck test' running around the layout in a B&T livery paired with a 141 Ah well, in for a penny, in for a pound: 121 class model to play with in the mean time Edited April 27, 2017 by Noel Quote
Kirley Posted April 27, 2017 Posted April 27, 2017 Should look the part(from a distance anyway) Noel when you get it finished. Is that a Shapeway body? Quote
Warbonnet Posted April 27, 2017 Posted April 27, 2017 Hi Noel, great to see you're working on a model, but not sure it fits in on this thead as it's to do with the Murphy 121 and you have also posted it elsewhere. Cross posting is discouraged. Thanks. Quote
Noel Posted April 27, 2017 Posted April 27, 2017 Hi Noel, great to see you're working on a model, but not sure it fits in on this thead as it's to do with the Murphy 121 and you have also posted it elsewhere. Cross posting is discouraged. Thanks. Apologies Fran, no prob. That's why I made short post here with the other 121 related posts, but a link to the long post on the workbench thread. Noel Btw, any news on likely ship date for the Murphy Model 121? Quote
RedRich Posted April 27, 2017 Posted April 27, 2017 Apologies Fran, no prob. That's why I made short post here with the other 121 related posts, but a link to the long post on the workbench thread. Noel Btw, any news on likely ship date for the Murphy Model 121? Why don't you contact Murphy Models and ask them. Rich, Quote
