Anders112 Posted April 14, 2024 Posted April 14, 2024 14 minutes ago, derek said: Hi Oisin. Thanks for the reply, but I can't seem to download your videos. Thanks nonetheless for taking time to upload them. From what you say in your reply, we seem to have similar set ups (and similar problems). I too use a pair of Hornby controllers. I have never had a problem before this with any of my locos. I have emailed IRM about it so we will see what develops. I wonder if anybody else is having this problem? (Although most probably use DCC) .Thanks again for the reply. Derek Hi Derek and Oisin,my Irish rail 181 made a similar noise when I first ran it on my DC layout. Got worried like yourself thinking there was something wrong. On the instructions it says you have to let the gear in the motor to bed in by running it for a hour in each direction without any load . Left it running for two hours and have noticed the noise has faded significantly hope this helps thanks Dave 2 Quote
226 Abhann na Suire Posted April 14, 2024 Posted April 14, 2024 1 hour ago, derek said: Hi Oisin. Thanks for the reply, but I can't seem to download your videos. Thanks nonetheless for taking time to upload them. From what you say in your reply, we seem to have similar set ups (and similar problems). I too use a pair of Hornby controllers. I have never had a problem before this with any of my locos. I have emailed IRM about it so we will see what develops. I wonder if anybody else is having this problem? (Although most probably use DCC) .Thanks again for the reply. Derek Not a bother Derek, happy to help if I can. Ohh ok that’s weird, I’m not sure what happened there then, there’s not much to the videos though I was just demonstrating the sound it makes but looking at the video you have on the other thread, the sounds are similar. Yes I’d say you’re dead right, it’s likely down to the controller. I’ve had a similar sounds off of other locos before so I presumed it was just the way certain locos sound on DC and didn’t see it as much of a problem, and to this day all of my stock runs perfectly. Do any of your other stock, MM or otherwise have similar issues? 1 hour ago, Anders112 said: Hi Derek and Oisin,my Irish rail 181 made a similar noise when I first ran it on my DC layout. Got worried like yourself thinking there was something wrong. On the instructions it says you have to let the gear in the motor to bed in by running it for a hour in each direction without any load . Left it running for two hours and have noticed the noise has faded significantly hope this helps thanks Dave Ahh ok well that’s it then I’d say! Thanks a million for the help Dave, case closed!! Quote
derek Posted April 15, 2024 Posted April 15, 2024 23 hours ago, 226 Abhann na Suire said: Not a bother Derek, happy to help if I can. Ohh ok that’s weird, I’m not sure what happened there then, there’s not much to the videos though I was just demonstrating the sound it makes but looking at the video you have on the other thread, the sounds are similar. Yes I’d say you’re dead right, it’s likely down to the controller. I’ve had a similar sounds off of other locos before so I presumed it was just the way certain locos sound on DC and didn’t see it as much of a problem, and to this day all of my stock runs perfectly. Do any of your other stock, MM or otherwise have similar issues? Ahh ok well that’s it then I’d say! Thanks a million for the help Dave, case closed!! On 14/4/2024 at 2:18 PM, Anders112 said: Hi Derek and Oisin,my Irish rail 181 made a similar noise when I first ran it on my DC layout. Got worried like yourself thinking there was something wrong. On the instructions it says you have to let the gear in the motor to bed in by running it for a hour in each direction without any load . Left it running for two hours and have noticed the noise has faded significantly hope this helps thanks Dave Hi lads, thanks for taking the time. Like you Dave, after I ran the loco in for an hour in each direction, the noise does seem to have diminished ( or am I just telling myself that). No, seriously it does seem better. And Oisin, I also run another 141 from the original run with no noise problems. 2 1 Quote
steventrain Posted April 15, 2024 Posted April 15, 2024 (edited) I was at Modellers Corner Model shop in Enniskillen have MM141s 8 versions in stock. Edited April 15, 2024 by steventrain 2 Quote
spudfan Posted April 15, 2024 Posted April 15, 2024 RB Models in Clonmel have them too. At €225 they are slightly cheaper than any where else. I have bought previous Murphy Models from them in the past. Sadly I will be giving this batch a miss as they are outside my budget. Nice locos though! Locomotives Archives - RB Models 1 1 Quote
Newtoncork Posted April 16, 2024 Posted April 16, 2024 IE 163 arrived this morning, herself was here, so had to own up. She especially liked the dayglow panels and how heavy it is. The distraction tactics worked. Next one is that they worked in pairs.......... 4 7 Quote
Broithe Posted April 16, 2024 Posted April 16, 2024 4 minutes ago, Newtoncork said: IE 163 arrived this morning, herself was here, so had to own up. She especially liked the dayglow panels and how heavy it is. The distraction tactics worked. Next one is that they worked in pairs.......... You need to sign out now, assuming she doesn't have access to your password - then sign back in hourly and report on your wellbeing... 7 Quote
spudfan Posted April 16, 2024 Posted April 16, 2024 2 hours ago, Newtoncork said: IE 163 arrived this morning, herself was here, so had to own up. She especially liked the dayglow panels and how heavy it is. The distraction tactics worked. Next one is that they worked in pairs.......... Emphasise the "they worked in pairs" angle. Say "they worked in pairs" just like us.... 6 Quote
irishmail Posted April 16, 2024 Posted April 16, 2024 5 hours ago, Newtoncork said: IE 163 arrived this morning, herself was here, so had to own up. She especially liked the dayglow panels and how heavy it is. The distraction tactics worked. Next one is that they worked in pairs.......... And don't forget the third loco for 'Standby' purposes... 1 3 Quote
Broithe Posted April 16, 2024 Posted April 16, 2024 9 minutes ago, irishmail said: And don't forget the third loco for 'Standby' purposes... Steady! He's been missing for five hours now... 1 1 2 Quote
spudfan Posted April 16, 2024 Posted April 16, 2024 5 hours ago, irishmail said: And don't forget the third loco for 'Standby' purposes... Bad idea, she might think you are hinting at threesome territory.... 1 3 Quote
Robert Shrives Posted April 19, 2024 Posted April 19, 2024 Just to add on the three some!! I now have 2 from first batch and 154 from this batch and all lovely models. now need to find time to build suitable layout in my loft - slightly more possible as found some boards in good order - albeit 50 years old! This loco will get a spot of filth for fun. Robert 2 Quote
Flying Snail Posted April 19, 2024 Posted April 19, 2024 (edited) Since we're still speaking of threesomes: Just received notification from An Post that I have three on their way to me today Don't worry - herself is at work and the dog won't grass me up Edited April 19, 2024 by Flying Snail 2 3 Quote
Newtoncork Posted April 19, 2024 Posted April 19, 2024 Good stuff Flying Snail! Put the 'Hide Them From Herself' plan into action. 1 Quote
Flying Snail Posted April 19, 2024 Posted April 19, 2024 Oh, they'll be well hid! My fall back line when she happens across me playing with a new loco that she hasn't seen before is that the liveries are interchangeable - vinyl overlays or some such 1 2 Quote
Anders112 Posted April 19, 2024 Posted April 19, 2024 (edited) Latest two arrivals to my Drogheda and platin layout… there’s just something about the tippex livery with the dayglo 154 came in the post today and just like @Flying Snail 189 was last week adventure of trying to get home from work before the post man landed with it Edited April 19, 2024 by Anders112 6 Quote
Flying Snail Posted April 19, 2024 Posted April 19, 2024 40 minutes ago, Anders112 said: Latest two arrivals to my Drogheda and platin layout… there’s just something about the tippex livery with the dayglo Nice .. 154 was one of my three Babies today! 1 Quote
Darrman Posted April 19, 2024 Posted April 19, 2024 Got my 141 today. I decided to dust off the train set and run it, but a paper mat over carpet is not a good running surface at all, and it was a struggle to record these clips. Don't mind the livery mismatches and the HST cameos - I wanted a black and tan 141 to have a black and tan loco. What if I told you it was actually an MGWR HST? 20240419_221431.mp4 20240419_205957.mp4 4 Quote
irishmail Posted April 20, 2024 Posted April 20, 2024 Well, at least you did not run it directly on the carpet like a certain person on youtube. Quote
WRENNEIRE Posted April 21, 2024 Posted April 21, 2024 So I got my delivery of chips on Friday I also ordered some more 121 ones Plain chips OK DCC 121 MM567 MM645 141 MM567A MM645A Any idea why there are 2 versions for each loco, Maybe separate one for the 141 & 181 but why 2 for the 121's? Have a few Peroni Nastro Azzuro's on board so grey cells are not up to scratch 1 1 Quote
irishthump Posted April 21, 2024 Posted April 21, 2024 7 minutes ago, WRENNEIRE said: So I got my delivery of chips on Friday I also ordered some more 121 ones Plain chips OK DCC 121 MM567 MM645 141 MM567A MM645A Any idea why there are 2 versions for each loco, Maybe separate one for the 141 & 181 but why 2 for the 121's? Have a few Peroni Nastro Azzuro's on board so grey cells are not up to scratch They are for the 2 different engine types. Both the 141's and 121's originally had the 567 while the 181's were fitted with the 645. Many of the 141's and 121's were later re-engined with 645's taken from the withdrawn C Class locos. 4 1 Quote
DJ Dangerous Posted May 27, 2024 Posted May 27, 2024 I see that the new 141's / 181's have almost sold out at IRM, but Mark's Models still have the full range in stock. Why the discrepancy in the rate of sales, I wonder? 1 Quote
irishmail Posted May 27, 2024 Posted May 27, 2024 Marks models seem to have a higher mark up on items for some reason, one example is the Hornby TT:120 Scotsman train set which is €299.99 from Marks or €274.95 direct from Hornby. Modellbahn Union in Germany currently have it for €247.46. 1 Quote
DJ Dangerous Posted May 27, 2024 Posted May 27, 2024 55 minutes ago, BosKonay said: Points? Free post? IRM were pretty on the ball with the pre-ordering campaign, too. Lots of fanfare on the forum, plenty of mail-outs etc. Mark's were quiet as a mouse, as if the launch was a secret. Free post? Free post??? I hear it's raining a lot lately. Good enough for you, you and your free post! 21 minutes ago, irishmail said: Marks models seem to have a higher mark up on items for some reason, one example is the Hornby TT:120 Scotsman train set which is €299.99 from Marks or €274.95 direct from Hornby. Modellbahn Union in Germany currently have it for €247.46. You want a TT Class 50 to go with that? 1 Quote
irishmail Posted May 27, 2024 Posted May 27, 2024 Just now, DJ Dangerous said: IRM were pretty on the ball with the pre-ordering campaign, too. Lots of fanfare on the forum, plenty of mail-outs etc. Mark's were quiet as a mouse, as if the launch was a secret. Free post? Free post??? I hear it's raining a lot lately. Good enough for you, you and your free post! You want a TT Class 50 to go with that? Lol yes, I have 50040 on order from Hornby, hopefully be shipped tomorow or wednesday. 1 Quote
Georgeconna Posted May 27, 2024 Posted May 27, 2024 4 hours ago, BosKonay said: Points? Free post? Exactly that! Quote
spudfan Posted May 28, 2024 Posted May 28, 2024 RB Models in Tipperary. €220 with free postage. Locomotives Archives - RB Models 2 1 Quote
DJ Dangerous Posted June 1, 2024 Posted June 1, 2024 On 27/5/2024 at 7:17 PM, irishmail said: Lol yes, I have 50040 on order from Hornby, hopefully be shipped tomorow or wednesday. You sly devil, you: https://railsofsheffield.com/products/hornby-tt3014m-class-50-co-co-50040-leviathan-br-diesel-locomotive On 28/5/2024 at 7:36 PM, spudfan said: RB Models in Tipperary. €220 with free postage. Locomotives Archives - RB Models So they're beating IRM on price? Quote
LNERW1 Posted June 1, 2024 Posted June 1, 2024 Absolutely nothing to do with the topic, but love @DJ Dangerous’s new profile pic! 1 Quote
Ironroad Posted June 1, 2024 Posted June 1, 2024 Thinks he's Captain America now !!!!!!!!!!!! 1 Quote
DJ Dangerous Posted June 1, 2024 Posted June 1, 2024 20 minutes ago, Ironroad said: Thinks he's Captain America now !!!!!!!!!!!! Captain Nostalgia! 30 minutes ago, LNERW1 said: Absolutely nothing to do with the topic, but love @DJ Dangerous’s new profile pic! Hey, I can do this all day. 4 Quote
DiveController Posted June 2, 2024 Posted June 2, 2024 (edited) On 27/5/2024 at 12:17 PM, BosKonay said: Points? Free post? Free for some … been discussed previously. But I do have some points. How do I access their value at checkout? IRM ordering process for ex-EU is much simpler than having to email Marks to refund the VAT which should not have been charged to begin with Edited June 2, 2024 by DiveController Quote
BosKonay Posted June 2, 2024 Posted June 2, 2024 6 hours ago, DiveController said: Free for some … been discussed previously. But I do have some points. How do I access their value at checkout? IRM ordering process for ex-EU is much simpler than having to email Marks to refund the VAT which should not have been charged to begin with At least we now charge by weight at cost for ROW To buy using points just open the rewards widget and click on the Redeem button and it will let you pick how many points to redeem which will then get placed into the cart / checkout as a discount code. Quote
