scahalane Posted October 26, 2014 Posted October 26, 2014 Fantastic build there popeye! The cast of the underframe looks very clean which is no easy job, I know I've tried it myself. I would be interested to know how you made the mould, was it in 2 parts or 3? Quote
iarnrod Posted October 26, 2014 Posted October 26, 2014 Excellent work. Hopefully Des from Studio Scale Models or someone else will bring out a full kit in the future. The cement bubble is such an iconic Irish wagon. Quote
RedRich Posted October 26, 2014 Posted October 26, 2014 Top marks for all the work, and the finished wagon. I will say that it is the finest bubble wagon I have seen. The chassis as already mentioned before is superb. The bubble from D&M look's great and the SSM kit really takes it to a higher level. I like the discharge pipes and the brake pipe connected to the uprights really gives it an authentic look. It is impressive modelling, well done. Rich, Quote
Georgeconna Posted October 26, 2014 Posted October 26, 2014 Masterful, Love the info on the parts as well, Great info..on the question side those number DLK 06 etc what are they in relation to, Dundalk works? Love the way you tackled the Ladder support, If you have not copyrighted it I might use it on my next lot!! Quote
Glenderg Posted October 27, 2014 Posted October 27, 2014 Love the way you tackled the Ladder support, If you have not copyrighted it I might use it on my next lot!! Dang, my thoughts also! I always thought it was Dept. Limerick for D-LK? Snapper would be the man to ask :-) Quote
ttc0169 Posted October 27, 2014 Posted October 27, 2014 Dang, my thoughts also! I always thought it was Dept. Limerick for D-LK? Wagon has had a"D"exam in Limerick wagon works in 2006, Nice job on the bubble btw. Quote
popeye Posted October 27, 2014 Author Posted October 27, 2014 Thank's for the feedback on the cement wagon. The rubber mould is made by placing the part to be cast face up and glued down so it sits flat and won't move in a container just a wee bit bigger than the part and pour the rubber over it, making sure it covers it all by about 1cm. I pour a small amount on first and make sure it goes into all the little corners. It takes about a day to set and the rubber is very tough. Give it a go. Quote
popeye Posted May 14, 2015 Author Posted May 14, 2015 Bredin Coach with Brass etch sides. I have had a go at converting a Dapol coach with JM Designs brass etch sides. cutting the plastic sides off to start with was a bit of a job and nearly lost a few fingers. I also added small door handles, soldered on. And i used 2 Bachmann Commonwealth Bogies. The seating was all hand built and 6 people added near the windows so they can be seen. The pipework on the roof was made with 1mm plastic rod and torpedo vents from MJT. The green paint was mixed myself until i had a shade i was happy with. I will make the next one without using the plastic body shell and i will use brass plate for the floor & ends then solder the sides to that. 2 1 Quote
Glenderg Posted May 14, 2015 Posted May 14, 2015 Lovely work sir. Aside from the shade of green Quote
StevieB Posted May 15, 2015 Posted May 15, 2015 Very nice indeed -do you have any more photos of the early construction stage? Stephen Quote
Weshty Posted May 15, 2015 Posted May 15, 2015 Jawdropping. Very clean lines. I thought one of the shots was a CAD picture it was so clean! Mayner, you must be a proud daddy of your product after that. Quote
Noel Posted May 15, 2015 Posted May 15, 2015 . . . I thought one of the shots was a CAD picture it was so clean! I did too. It is sublime. Quote
Dunluce Castle Posted May 15, 2015 Posted May 15, 2015 That coach is just so perfect, it's amazing, well done Quote
josefstadt Posted May 15, 2015 Posted May 15, 2015 Fantastic work on the coach Popeye and also on the cement bubble. Quote
Mike 84C Posted May 15, 2015 Posted May 15, 2015 A brilliant piece of modeling! How did you keep the glazing so clear and what did you use? Quote
Mayner Posted May 15, 2015 Posted May 15, 2015 Jaw dropping Patrick, an excellent show case for JM Design coach sides; the high overall standard of finish, subtle weathering, really clean lines sharp interior detailing. The plastic in the Dapol shells is not the easiest to work with I ended up cutting out the windows with a mini cutting disc mounted in a Dremel flexible drive rather than use a knife. To me the biggest mystery is how you get the Dapol roof to sit flat on top of the sides, Quote
richrua Posted May 15, 2015 Posted May 15, 2015 Yes I also thought that was a Cad type shot !!! Wonderful. Something to aspire to. Quote
popeye Posted May 16, 2015 Author Posted May 16, 2015 Thank's for all your comments. It took a few months to build and i don't have anymore pic's of the construction but i will take more on the next build. The glazing is just clear plastic which is not that clean and scratched if seen closeup. the roof is just sitting their and still needs to be fixed down properly. The next one will be Black & Tan. Quote
popeye Posted June 2, 2016 Author Posted June 2, 2016 SOME NORTHERN ROLLING STOCK A studio Scale Models brass brakevan A Cambrian open wagon A Provincial Wagons 10 Ton fitted van. Quote
JasonB Posted June 2, 2016 Posted June 2, 2016 They look great,that weathering is excellent,so realistic. Quote
Georgeconna Posted June 3, 2016 Posted June 3, 2016 Now that is quite something to savour. Top class work. Are those coach side still available? Quote
flange lubricator Posted June 3, 2016 Posted June 3, 2016 Great work Popeye the weathering add's that extra level realism to the models. Quote
Weshty Posted June 3, 2016 Posted June 3, 2016 Oh that is so money. Great subtle weathering, good backdrop, nicely lit and photographed. Well done sir. Very well done. Quote
